| Vista Home Premium 32bit | TV tuner Hi I bought a Compro Videomate Vista E700 tv tuner and plugged it in and it cant find any channels, even when it is plugged into an aerial on the roof. any help would be grateful Thanks |
| Windows 7 Ultimate 32Bit (Build 7600) | Re: TV tuner Have you re-configured VMC for your new tuner and checked that the program guide data is correct? Regards UKMedia |
| Vista Home Premium 32bit | Re: TV tuner Hi UKMedia Thanks for your reply but im not brilliant with computers so can you please tell me what the VMC is and how to configure it? Thanks |
| Windows 7 Ultimate 32Bit (Build 7600) | Re: TV tuner Sorry if I didn't make it clear. Try this:
Regards UKMedia |
| Vista Home Premium 32bit | Re: TV tuner Thanks for the help but unfortunantly that hasn't worked either. I've also tried uninstalling the software and installing it again but that hasn't worked. Any more ideas would be much appreciated |
| | #6 (permalink) |
| Windows 7 Ultimate 32Bit (Build 7600) | Re: TV tuner If you go into Control Panel>Device Manager do you see your tuner card and if so is it reporting it as okay within it's properties? Also, have you tried downloading the latest driver from the web site: http://www.comprousa.com/en/download/ve700.html Regards UKMedia Last edited by UKMedia; 06-09-2009 at 02:53 PM.. Reason: Adding driver link |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: TV tuner Hi I have downloaded the latest driver from the webiste and it still doesn't work. I also checked the status of the drivers and there are working properly according to the properties menu. |
| | #8 (permalink) |
| Windows 7 Ultimate 32Bit (Build 7600) | Re: TV tuner Ok - Idea 3 Have you tried a normal TV connected to the Aerial? Have you the opportunity to try the tuner in another PC? Regards UK Media |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: TV tuner Hi Yes, I have tried plugging a digital tv into the aerial which I am using and it works fine picking up all the channels. Unfortunatley I don't have another computer to try the tv tuner in. I am still puzzled why it's not working Any more ideas? |
| | #10 (permalink) |
| Vista Ultimate SP2/Windows 7 Ultimate x64 | Re: TV tuner It seems to be a universal problem. Some theories suggest certain security software treats WMC as a network device when it isn't. Dell Forums is full of complaints about the same thing. I can only get it to work sometimes, it seems to depend on its mood, not kidding. |
| TV tuner | Media Center | |||
| TV tuner | Vista hardware & devices | |||
| TV Tuner? | Media Center | |||
| TV Tuner help | Graphic cards | |||
| How Do You Get a Tv Tuner | Vista General | |||
