Go Back   Vista Forums > Vista Forums > Media Center
Vista Tutorial - WMP11 Playing in Slow Motion
Old 06-07-2009   #1 (permalink)
Newbie
Vista Home Premium 64 bit
I am having a problem playing my newer AVI files on in windows media player. The older AVI files play, but the new ones are starting to give me problems. They were playing fine before but have now started to play in slow motion. The sound is normal, but the video plays very slow. The play speed settings are set on 1.0 but won't change if I press normal fast or slow. My computer has an AMD 2 ghz chip, 4 gigs of ram. Any help would be appreciated!
Old 06-07-2009   #2 (permalink)
Vista Home Premium 64-bit
Re: WMP11 Playing in Slow Motion
Frame-rate... hmmm... what video card do you have?
Old 06-07-2009   #3 (permalink)
Newbie
I'll have to double check that, but does it matter if the videos play ok when I used quicktime?
Games in Slow Motion When I Activate DirectX 10 Vista hardware & devices
SLOW motion after install of Vista Home Primium 64 Vista installation & setup
WMP11 runs in Slow Motion Vista music pictures video
Audio & Visual Play Back in Slow Motion Vista music pictures video
Windows Vista Installation - Recommended Specs, but slow motion Vista installation & setup
