| Vista Home Premium 32bit. | Opening Media Center failure problem I can't do anything with my Media Center. I get a pop up window when I try to open it. It reads: Media Center has stopped working A problem caused the program to stop working correctly. Please close the program. Anyone can help with this problem. |
| Vista | Re: Opening Media Center failure problem What else is going on with the PC when this happens? Are there any other programs running (either in the background or in the foreground)? Does the screen at least advance to the blue Media Center Screen and then you get the popup, or does the popup happen before that? Let me know. Cheers, |
| Windows Media Center Vista - Opening Screen Has Blinking Lines of | Vista performance & maintenance | |||
| All programs opening up in Windows Media Center | Vista General | |||
| failure to upgrade from media center XP to vista business edition | Vista installation & setup | |||
| Vista Ultimate and Media Center - Recording TV after power failure | Vista music pictures video | |||
| Media center is opening most but not all of the .exe file extensio | Vista General | |||
