Go Back   Vista Forums > Vista Forums > Media Center
Vista - PLEASE HELP!! DVD / CD Wont play
Old 07-16-2009   #1 (permalink)
vista home premium 64 bit
Brand new Gateway Laptop. It will not play any DVD's or CD's. I've tried to uninstall and reinstall drivers. I've done the upper and lower filter fix it. I've reinstalled factory settings. Nothing works... Can anyone help
Old 07-16-2009   #2 (permalink)
Windows 7 Ultimate x64 (Bata) & Windows Vista Ultimate x64 Sp2 & Windows XP Professional x32 Sp3
Re: PLEASE HELP!! DVD / CD Wont play
What codecs are you using? If you have a x64 OS you will need to install both x32+x64 for everything to play right. I recommend ffdshow or shark codec pack
Ok maybe never mind. I just reread your Q and saw the cd part. so it may be a hardware prob.
Old 07-16-2009   #3 (permalink)
Vista Ultimate x64
so, the computer knows the drive is there, but it won't let anything play?
So You start the computer.
Open the DVD drive, put in a disc, and close it.
What happenes next?
If nothing happens, it could just be a bad autorun file or something silly. Try exploring the drive, do you see any data?
If the computer doesn't recognize the drives, it could be a simple hardware problem, make sure they are connected properly.
DVD wont play Vista General
Sounds wont play Sound & Audio
My AVI FILES WONT PLAY ? Vista music pictures video
DVD wont play in WMC Vista music pictures video
help cd's wont play Vista hardware & devices
