| Vista Home Premium 32bit | CODEC issues - No sound on live TV and recorded TV After 6 good months where everything worked just fine, I have now lost the sound on Live TV in windows media center, and there is no sound when I playback recorded TV in Media Center. In addition I have the following observations: No "introduction sound" - when media center starts. No sound when I try "Configuration of speakers" in Media Center Sound works fine when playing music Sound works fine when playing the recorded TV programs in Media player - in other words, the files are intacts - it is just Media Center that does not work Based on the above I assume taht I have problems with my CODECS. Problem is - I have no clue how to fix it! ![]() Where do I go from here? |
| Vista 32 win 7 7600 32 bit | After 6 good months where everything worked just fine, I have now lost the sound on Live TV in windows media center, and there is no sound when I playback recorded TV in Media Center. In addition I have the following observations: No "introduction sound" - when media center starts. No sound when I try "Configuration of speakers" in Media Center Sound works fine when playing music Sound works fine when playing the recorded TV programs in Media player - in other words, the files are intacts - it is just Media Center that does not work Based on the above I assume taht I have problems with my CODECS. Problem is - I have no clue how to fix it! ![]() Where do I go from here? Ken |
| Vista Home Premium 32bit | Can you guide me on how to do this? I have never myself installed any additional CODEC packs - so not sure where/how to uninstall. |
| Vista home premium 32bit | Media center and media player use the same codec sources on your system. If it works in media player, a codec problem is very unlikely. My guess is that some media center file got corrupted. You can run SFC /SCANNOW in cmd (open as admin). Maybe it can fix it. |
| Vista 32 win 7 7600 32 bit | Whs is correct if you haven't installed any codec's then only the ones internal to vista are installed. try wha suggestion of running the system file checker (sfc /scannow). Let us know how it works out Ken |
| ASRock A-Live XFire e-sata2 sound issues | Sound & Audio | |||
| Edit Recorded Sound | Vista General | |||
| No sound on LIVE TV/ RECORDED TV | Vista General | |||
| monitoring recorded sound - vista | Vista music pictures video | |||
| recorded TV sound problem | Vista General | |||
