Go Back   Vista Forums > Vista Forums > Media Center
Vista - TV Tuner Setting
Old 08-28-2009   #1 (permalink)
Window Vista Home Premium 32 bit
TV Tuner Setting
I am trying to set-up my TV settings and the windows media center is only scanning for digital air signals. I thought it might be my TV tuner card because my windows media center on my other computer work fine finding my cable TV. So I switch cards and the same thing happen with the second card. I tried Total media and it appears to be fine with either cards on the computer in which I am having the issues. Any thoughts?
Old 08-28-2009   #2 (permalink)
Vista Ultimate 32 bit; Vista Home Premium 32 bit ;Vista Home Premium 64 bit;Windows 7 .
Re: TV Tuner Setting
Quote  Quote: Originally Posted by sontch View Post
You don't provide enough info for anyone to advise you...however all the info you could wish for is on the following site : Windows 7, Vista & Linux Media Center Support Community
There is much more to building an HTPC than just adding a tuner..it's all relative to makes and models of components plus the OS etc. Best advice I can give is to go join XPMediaCenter and search for your answer or ask the question...you will find your answers there.
Setting Associations Setting a file type with a specific file in V Vista General
Setting restore point weekly using Task Scheduler is not setting RP. Vista performance & maintenance
Setting restore point weekly using Task Scheduler is not setting RP. Vista General
TV Tuner not found when setting up TV in Media Center Vista hardware & devices
TV Tuner not found when setting up TV in Media Center Vista General
