Go Back   Vista Forums > Vista Forums > Media Center
Vista - Wake up on USB with remote
Old 09-01-2009   #1 (permalink)
Win 7 Ultimate
This is in response to this tutorial (Hopefully Brink will see this thread
Power Options and Sleep Mode Problems
ok here is a summary. (It's sending me mad so I am grateful for any help)
I want to be able to wake from s3 with my Dvico usb remote.
State of play:
Wake on USB is possible from my bios as I have a wheel mouse that will wake from USB.
My Dvico remote is listed when I run the following powercfg commands:
wake_fromS3_supported
S3_supported
It is not listed under:
wake_armed.
Under device manager for this device under power management under the root hub, I can turn on/off allow this device to be switched off by the computer to save power, it's currently unselected.
When I expand down any lower levels to the device itself there are no power management options.
So given my bios/motherboard are configured to wake on usb as evidenced by being able to wake wiht the usb mouse. How do I get remote to be "wake_armed" which seems like the only missing component.
I have been working on this for over a week and my sanity is strained, thankful for any help.
Additonal:
I bought a usb pci card and I cannot wake fromthis device either details as above.
This is on wion 7 Ultimate though I thought I would post here as it is the most relevant discussion I have found regarding this. (And the best tutorial.)
checked for logged on user on remote machine + remote reboot PowerShell
Vista Wont Sleep, Want To Wake Up With MCE Remote Vista hardware & devices
my computer doesn't wake up with IR remote Vista installation & setup
wake up don't work with remote Vista hardware & devices
How WAKE computer to use Remote Desktop? Vista networking & sharing
