Go Back   Vista Forums > Vista Forums > Media Center
Vista - connect burner
Old 09-17-2009   #1 (permalink)
windoes xp
connect burner
I have three computers. Two have Vista already on them. I yet to update the third so I have XP on it. Media 11 says connect burner, how do I go about this.
Old 09-19-2009   #2 (permalink)
Vista Ultimate x64, SP2
Re: connect burner
Hello kandieoneluv,
Is this on the XP or Vista machine ?.
By burner, it means a CD/DVD drive, confirm that your drive is working, try playing a CD/DVD.
Also you can go to Device Manager, un-install the drivers for you CD/DVD drive and reboot, it will reload the drivers on boot up, and confirm that your drive is being recognised by Vista.
Right click on the icon of your CD/DVD drive from within My computer > properties > recording tab, check to see if it's set to record from your device.
Try this and post your results, good luck.
If this does not work there are other solutions to the problem, it's just this is the easiest to start with.
No burner is currently available or you don't have rights to access the burner. Vista hardware & devices
Can't connect to the internet, 3rd BRAND NEW computer that work connect! HELP! Network & Sharing
what does connect a burner and restart player mean? Vista General
Built-in CD Burner or 3rd party Burner? Vista General
dvd burner Vista General
