| x64 | Error: Catalystmc not install!! USB TV Tuner Hello. I'm new to the forum. I haven't had a lot of time to look through here but have intentions to do so. I was hoping I could get some help from someone smarter that I. I purchased a Diamond ATI USB 600 TV Tuner that I'm fairly happy with. It plays TV. ![]() Anyway, a remote came with it that just won't work. When I press the power button, I receive a pop-up error that says "CatalystMC not install;" however, I've installed this application and believe I've been using it to watch TV. When I try to run the installer again it tells me that everything is installed and up to date. I've tried re-installing it as well as repairing it. I did notice that the ATI stuff is under my regular "Programs" folder and my controller stuff is under my "programs x86 folder". Thoughts? |
| x64 | Re: Error: Catalystmc not install!! USB TV Tuner problem solved: remote will not work with total media center. Diamond is sending catalyst media center. |
| TV Tuner failing after SP1 install on Vista Ultimate | Vista music pictures video | |||
| Error Installing TV Tuner card | Drivers | |||
| TV Tuner not Found Error in WMC | Media Center | |||
| WU: Tuner Drivers will not install | Vista hardware & devices | |||
