Go Back   Vista Forums > Vista Forums > Media Center
Vista - Media Center TV recording problem
Old 10-18-2009   #1 (permalink)
Vista Ultimate x64
I tried recording a couple of shows while I wasn't home. Only 2 minutes of each show was recorded. I left my computer running and I made sure I had plenty of room on my hard drive. The only thing I can think happened was that my computer went into sleep mode and interfered with the recording of the shows. Is this a common issue and how can I fix it?
Old 10-19-2009   #2 (permalink)
Vista Home Premium 64bit
Re: Media Center TV recording problem
Confirm you PC did indeed go into sleep mode...if that's what happened then turn sleep mode off when you have something you want to record.
Old 10-19-2009   #3 (permalink)
Vista Ultimate x64
I checked the event viewer. There were several warnings listed:
1. Recording began late due to temporary failure caused by system malfunction or power loss.
2. Recording began as scheduled and stopped early because of a conflicting recording.
3. Program was not recorded because of a tuner failure
How can I check if any of these were caused by my pc going into sleep mode?
media center manual recording problem Vista General
Media Center recording old programs? Vista General
Media Center Recording Vista General
Media Center Recording On It's Own Vista music pictures video
Vista Media Center - 2 Tuners Problem with Recording Vista General
