wmp 11 won't add to library , won't add media info
  1. #1
    Newbie
    vista home premium 64
    Local Time: 03:55 AM
    New problem , was working five weeks ago , have tried system restore (6 times!)
    When ripping a new CD in WMP 11 , the CD is identified as unknown album, unknown artist (have tried several new CD's ) use find album info , info is found but will not 'attach '' to the tracks (edit info will not work either), also album does not go into WMP library, but will play from the folder it is in. Even after playing is still not in library even though this option is selected in library options , and the folder the files are in shows as a monitored file.
    Any ideas how to get it back to working ok - have tried SFC
  2. #2
    derekimo's Avatar
    Senior Member
    East Bay Area, CA
    Windows 7 Pro 64 SP1
    Local Time: 02:55 AM
    usa us california
    Re: wmp 11 won't add to library , won't add media info
    Hello libr8r,
    I'm not sure if this is exactly what is going to solve your problem but since you've tried system restore and sfc, you might want to give this a shot.
    Windows Media Player 11 Won't Let Me Add or Delete Music
  3. #3
    Newbie
      Thread Starter
    Big thanx
    this sorted my problem out.
    bug kudos to you
  4. #4
    derekimo's Avatar
    Senior Member
    East Bay Area, CA
    usa us california
    You're Welcome, Glad I could help.
wmp 11 won't add to library , won't add media info problems?
Different album info in Media Centre to Media Player Library rwbarrett Media Center 3 03 Mar 2009
vista media player media library doesn't index my mp3 files Tom Vista music pictures video 21 25 Feb 2007
Adding media to the wmp library? jay bob Vista music pictures video 5 07 Feb 2007
Can't copy media files into media library if WMP11 is open. Dale Vista music pictures video 0 10 Nov 2006
Media library sharing =?Utf-8?B?di02dWRheXQ=?= Vista networking & sharing 0 21 Aug 2006
