Audio-video not synch
  1. #1
    Banned
    Manhattan, New York
    Vista Home Premium 64bit
    Local Time: 05:37 PM
    usa us new york
    Almost always, (NOT ALWAYS), when I fast forward web video playback, video and audio do not synchronize...often audio is delayed by seconds. Not sure, but I think this is a recent development with updated Flash Player. Old versions are no longer downloadable.
    Any suggestion?
  2. #2
    kesume's Avatar
    Senior Member
    Lake District, England
    vista Home Basic 32bit
    Local Time: 11:37 PM
    uk uk yorkshire
    Re: Audio-video not synch
    Hi welcome to the forum.
    The obvious questions first.
    Have you checked in Device Manager to make sure all your drivers, video card, etc is up to date?
    There are no little yellow warning signs that indicate problems?
    Did this problem only start after you downloaded Flash Player, or could it have been present before???
    What version of FP id you have, what version did you update to?
    Thank you.
    How recent is it, a few days?
  3. #3
    Banned
    Manhattan, New York
    usa us new york
      Thread Starter
    It's been a while since I visited mature adult sites...where this video playback audio/video synchronization
    mismatch happens. Other Video playbacks (on Media Center, HP quickplay, Sidereel and TV channel sites and IE 8 browsers' Fox sports and MSN News Videos) are totally normal even those using FP. Is it possible it's the adult site problem and not my PC or FP?
    I am always using the most current updated FP because I had it set up on auto-updating mode. That means I was auto updated from the previous version which happened in February...but I did not notice this new prob in synch until just a few days ago. I do not remember ever having this prob before.
    All my drivers were recently routinely checked and up-dated.
  4. #4
    kesume's Avatar
    Senior Member
    uk uk yorkshire
    If it has only literally a few days this has been happening?
    Or it is only in the last few days it has been noticed?
    I was just considering the possibility of a System Restore to a time before this problem appeared?
    Have you any restore points?
    Does the same instance occur on a number of sites or a particular one?
  5. #5
    americancritic's Avatar
    Senior Member
    Arizona
    Windows Vista Home Premium 64 bit Sp2
    Local Time: 03:37 PM
    usa us arizona
    Hello and welcome to the forum.
    If your thinking of doing a system restore to correct the problem you need to go back at least 5 days before the problem started. Here is a tutorial that will guide you.
    System Restore - How to
    System Recovery Options
    Please read them before doing one, unless of course you have done them before.
    americancritic
  6. #6
    Banned
    Manhattan, New York
    usa us new york
      Thread Starter
    The first time I noticed the prob, I did system restore with the earliest restore point, to no avail. I did sfc scannow and dskchk scan for error, memory and hard drive diagnostics, and defrag...all to no avail. Since then I have had at least 2 runs of anti-virus full scan with MSE(which I do routinely...twice a week) and two with MBAM.
    Maybe as a result of all these maintenance measures my system is faster and glitch-free except for this synchronization prob(which I have to repeat, happens only on some(NOT ALL) adult website video payback.
  7. #7
    Senior Member
    Arizona
    usa us arizona
    I am glad to see that you know about your system and we will continue to seek an answer for you...
  8. #8
    kesume's Avatar
    Senior Member
    uk uk yorkshire
    Well, as americancritic has stated we will continue to secure knowledge to come up with an answer.
    If you find a solution, please let us know.
    Thank you.
  9. #9
    Senior Member
    Arizona
    usa us arizona
    Hello TYPO can you tell us about any current error's in the event viewer. Maybe when this glich happens go the event viewer and see if there is any thing that would be around the times of the events them selves. But we are still looking into it for you.
  10. #10
    Banned
    Manhattan, New York
    usa us new york
      Thread Starter
    The event viewer shows 3245 errors and I cannot id an error about playback. I'm afraid it is too advance for me. Any clue what to look for?
Page 1 of 2 12 LastLast
Audio-video not synch problems?
Problem transmitting audio and video in WLM video calls Laserpulse Live Messenger 0 01 Nov 2009
WLM 9 - Video kaput 'We are unable to run audio & video setup' mes Mike Live Messenger 32 01 Apr 2009
how do I synch windows mail calendar with iphone since Outlook is only option for calendar synch cori traub Vista mail 1 01 Mar 2009
- Video kaput 'We are unable to run audio & video setup Katti41 Live Messenger 0 26 Feb 2009
Disc with Video & Audio files but PC only sees the audio Files Fezza Vista General 5 03 Nov 2007
