WMP: how do I import track info for a mix CD?
  1. #1
    Vista Ultimate x64
    Local Time: 11:52 AM
    Folks,
    I'm butting my head against the wall which is WMP.
    I've set my house up so I can stream audio from my Vista machine to my audio system. WM CENTER is the default program which my amp and network TV looks for, apparently. That's fine.
    The process of loading audio content seems to be that I insert a CD, rip it in WM PLAYER which loads into its library, and then WM CENTER imports the library contents. While it is ripping, I can select "download album info" and that imports all the song names, album title, etc. Once WM CENTER has it, I can set playlists, etc., search based on ratings, name, etc.
    The problem I have is importing a custom mix cd. If I insert a custom mix cd, WMP labels everything "Track 1, Track 2," etc. The cd gains the title "Unknown Title", "Unknown Artist", etc.
    How do I get WM CENTER to automatically download the track titles and associated information? Individually selecting every track and entering all the information for that track is asinine in this day and age. The information exists. I don't mind pointing (linking?) each track to its associated online information, but I have no clue how, or if, WM CENTER can do that. So far, it seems it can ONLY import information as a whole album.
    (In fact, another, associated problem, is that WM CENTER now thinks one of my custom cd's is an album. I cannot get WMC to stop mis-labeling the cd and all the tracks. Grrrr!!!)
    How do I import track information, for individual tracks?
    How do I dis-associate the wrong album information from a custom cd? (A mix cd.)
    Thank you,
    Ken
  2. #2
    Senior Member
    vista home premium
    Local Time: 12:52 PM
    Re: WMP: how do I import track info for a mix CD?
    I think the custom mixed cd was done without CD Text which would have all the individual titles, etc.
  3. #3
    Vista Ultimate x64
      Thread Starter
    Okay, the head-butting continues...
    Wall (which is WMP) 2: Head (me) 0
    I DELETED my ripped mix CD from WMP. I chose to delete from LIBRARY and COMPUTER.
    I inserted a newly burned CD, this time ensuring that "CD Text" had been selected.
    WMP immediately showed all the tracks as "already ripped". C'mon, guys. Give me a friggin' break. How the heck does DELETE work if it doesn't DELETE the file?
    So, CD "A" ripped but shows no track info. These are "ghost" songs that WMP cannot find. WMP only finds songs based on the album. That's so wrong.
    All CD "A" files deleted from WMP. (Or so I thought.)
    CD "B" = CD "A" + CD Text. Insert CD "B". WMP will not let be rip the songs because it is already ripped. Hence, the CD Text will not get imported. WTF???
    In the development and updates to WMP, surely the idea that a user would load music one song at time, rather than a full album at a time, was mentioned? WMP 11 (the version I'm running) surely must have SOME way for to download track information.
    What's the secret?
    How do I really delete music? Since, you know, the Library/select the music/select delete doesn't get rid of it.
    If I do manage to delete the music, then, maybe, I can find out of "CD Text" will import the track information.
    Ugh.
    Ken
  4. #4
    Senior Member
    vista home premium
    I assume your optical drive is capable of using CD Text. A great percentage are not. In most burning software, if your drive is not capable of CD Text, it may either not burn the CD, instead burning it to an image file, or burn it without the text.
    I can't answer your questions about WMP. I don't use it unless I have to. There's probably some .xml file someplace that tracks what's been done.
    Hopefully, someone else will chime in here.
  5. #5
    Newbie
    Windows XP
    Local Time: 06:52 PM
    Quote Originally Posted by iamc3k View Post
    It won't, at least not out of the box. WMP doesn't have built-in support for CD-Text, but you can install the WMPCDText plug-in to enable WMP to read CD-Text from audio CDs.
    In WMP, please go to Tools - Options - Privacy (press Ctrl+M if you don't see the Tools menu), and click Clear Caches. Can you rip the CD again now?
WMP: how do I import track info for a mix CD? problems?
Import News and Mail info Charles Live Mail 0 03 Feb 2010
how to select audio track to burn to DVD in dual track avi file? jds145 Vista music pictures video 3 07 Apr 2008
cant receive emails or import my outlook accoutn info erica russell Vista mail 3 28 Mar 2008
Import MSOE6 info from old hard drive to Windows Vista Mail? TomYoung Vista mail 1 18 Jul 2007
I can't import my old outlook info into my new microsoft mail Amy and Travis Vista mail 1 06 Jun 2007
