Guide listings only go out to 4/19, 6PM. I've tried reloading listings, but it tells me it's up to date.
It used to d/l at least 10 days worth of listings.
Bob
Bob
Hello Bob and welcome to the forums
Just to clarify, guide listings on what?
Tom
Sorry, I meant the TV guide listings for Windows Media Center, to set up recordings. I have a cable box connected to my HP Pavilion and I use it as a secondary DVR.
Bob
Hi Bob,
No problemI assumed it was this, but I just wanted to make sure before I started going down this route.
Let's try clearing the cache stored by WMC.
Please download and install CCleaner and CCEnhancer. The links to both can be found here:
Latest CCleaner version released
Install CCleaner first, then install CCEnhancer.
Once you've done this, open CCleaner. Do not go on the registry tab, this may cause more problems than it solves - all we want is the cleaner. You should see a large list on the left and two tabs at the top: Windows and Applications, select the Applications tab and scroll down to the Multimedia category. Towards the end of this section, you should see Windows Media Centre and Windows Media Centre More*. Tick both then click on Run Cleaner. This may take a few minutes to complete. Once it has completed, please reboot and let me know if you're still having the same problem
Tom
Tom,
I D/L the programs and once in the Applications tab of CC, I see WMC, but no WMC More. Will that make a difference?
BTW, I'm running Vista 64 bit, not 32 bit as stated on my profile.
Okay, that's great. Maybe I'm not running the latest CCEnhancer. It shouldn't make a difference, just do WMC
Tom
Tom,
I ran the CC, rebooted and tried to do a manual d/l of listings again. It started up for a second, then advised listings were complete, but no new listings were d/l.
I'm wondering if I should do a new setup of WMC?
Bob
Hi Bob,
Okay, that's a shame it didn't work, but there's plenty of other things to try. Yes, that would be a good idea. I'll do a bit of research whilst you do that.
Tom
You guys are just reinventing the wheel here. There are thousands of people having this problem. Here is the problem thread on The Green Button (Windows Media Center support group): http://www.thegreenbutton.tv/forums/...p=16568#p16568
View topic - Windows Media Center guide not updating - Unresolved
FYI, running CCleaner did not work for me either. The problem is at the
Microsoft-Zap2it level, not at the level of any individual pc or WMC configuration.
| Similar Threads | ||||
| Can't search guide listings to record a show | Pbb321 | Media Center | 0 | 09 Feb 2009 |
| Missing guide listings for 2nd HD channel 18-2 KLRU Create | DasWookie | Media Center | 1 | 05 Feb 2009 |
| Guide listings not available for Australia! Help! | Tristan-117 | Media Center | 0 | 22 Dec 2008 |
| Media Center has started to fail to update Guide listings | Frederick C. Wilt | Vista installation & setup | 3 | 08 Sep 2007 |
| how do i get the registry listings | IT Staff | PowerShell | 1 | 28 Dec 2006 |
