DVB S2 (TBS8920) Not detected
  1. #1
    Newbie
    Vista home premium 32bit
    Local Time: 07:27 AM
    Hi, I just got a DVB S2 tuner and installed it and it appears to be installed correctly.
    After considerable tweaking of the software it came with (dvb Dream) I tried it with Media center and it does'nt even appear to be detected as a valid source, getting the message 'no tuner is detected'.
    After a bit of looking baout I discovered there is a media center pack which I found and downloaded.
    When I go to install it, it says it is incompatible with my system !!!
    This is nuts !
    I've tried everything and I'm getting no-where fast !
    I'm runnning vista home premium 32bit on an asus m2a vm hdmi with an hd4870.
    Any ideas anyone ?
    Plz !!!!???!!!
  2. #2
    tom982's Avatar
    ٩(͡๏̯͡๏)۶
    England
    Windows 7 Ultimate x64 SP1
    uk uk england
    Re: DVB S2 (TBS8920) Not detected
    Hello Nelmac and welcome to the forums
    Can you post a link to the media centre pack that you downloaded?
    Tom
  3. #3
    Newbie
      Thread Starter
    'Can you post a link to the media centre pack that you downloaded?'
    Hi Tom, Unfortunately I deleted them !
    One was a media pack update 2008
    The other was dated 2010.
    I have another machine with xp 64bit and the installation went smoothly on that though.
    I now have a situation whereby, the other machine is an old machine and doesn't have a very good graphics card installed is not HD compatible !
    So, I've now got an HD tuner in a non HD machine !
    I downloaded the pack from the microsoft website and it was marked as being compatible with VISTA, however, as I said, when I went to install it, I got the message saying 'incompatible with my system' !!!
    Quite strange !
  4. #4
    Newbie
      Thread Starter
    Well, I've got it working with DVB DREAM but media center still can't recognise it !
    Annoyingly, I removed my M-AUDIO 2496 to make room for the DVB card because the m2a vm hdmi has only 1 pci slot, (being a micro ATX board).
    Using an external soundblaster, (sb0490), when DVB DREAM is running flashplayer has lost its AUDIO !
    The quest continues !!!!
DVB S2 (TBS8920) Not detected problems?
dvd/cd rom not detected rodneydlux General Discussion 12 29 Jun 2010
Mic not detected andy jones Vista hardware & devices 0 17 May 2010
usb not detected sarvjitarora46 Vista General 1 28 Jan 2009
CD rom not detected DD Vista hardware & devices 4 06 Aug 2007
CD rom not detected viboart Vista hardware & devices 1 24 Jul 2007
