Go Back   Vista Forums > Vista Forums > Media Center
Vista Tutorial - vista to xbox problems
Old 05-25-2007   #1 (permalink)
Newbie
i have vista 64 , xbox and an asus wl520g wireless ap
my problem is , getting the xbox to act as a media extender
xbox connects to xbox live therefore it works through the router to the net
pc see's the xbox
when i try to add extender , it says it cant find one
i've disabled all firewalls , tried removing the INFCACHE.1 file
anyone had the same sort of problem and solved it
Old 07-18-2007   #2 (permalink)
Junior Member
Vista 64
Re: vista to xbox problems
The problem cones with the public share. You must enable media sharing.
Make sure the xbox is on and you have cleared all existing network connections. Then use the xbox to establish a media centre connection get number etc.
This worked for me.
vista,xp and xbox 360 lots of problems Vista networking & sharing
Xbox 360 and Vista cannot find IP address from Xbox 360 Vista General
Problems getting Xbox 360 controller working with vista Vista hardware & devices
Xbox 360 and Extender problems in Vista Vista General
Xbox 360 and Vista extender problems. Vista General
