Go Back   Vista Forums > Vista Forums > Media Center
Vista - Media Center (64bit) (avi) trouble
Old 03-21-2008   #11 (permalink)
Vista Ultimate x64
Re: Media Center (64bit) (avi) trouble
Quote  Quote: Originally Posted by AZ93Civic View Post
Quote  Quote: Originally Posted by scrooge View Post
hello
will trying to play (avi) movies on Windows Media Center (64bit) i get a error that one or
more codes are missing to play the video? now today i tryed it and i get the audio but still
no video ? anyone no a fix or work around for this? the (avi)'s work fine with media player
but not Media Center? thank you very much for your time...
scrooge
Try this, but first uninstall all of your old codecs 1st -
codec cleaner : http://www.free-codecs.com/download_...hp?d=460&s=268
new codec pack : Here
Thank you so much for the post. it worked for me.
Here are some Monkey-see-Monkey-do instructions that I followed:
I removed all the codec using the "Programs and Features" applet in my control panel.
Then I downloaded the "codec cleaner". I unzipped it, opened it and clicked the "Run" button.
Final step, I downloaded and installed the "new codec pac".
That's it.
Now I enjoy my WMC.
Old 04-12-2008   #12 (permalink)
Vista Home Premium 64bit
Quote  Quote: Originally Posted by eggyuk View Post
Tried installing ffdshow but could not watch avi files in media center when that was installed. Any more suggestions?
I generally recommend NOT to install mega codec packs...you don;t need all of them you only need the one for that particular file...and even then I recommend converting the video file to something that doesn;t need to install a codec.
In your case you have so many codecs installed it confuses things and you'll get conflicts.
I hope your codec installer allows you to uncheck/uninstall the codec you don;t need.
Old 06-19-2008   #13 (permalink)
Xp-Vista-7
Here is an update to the thread:-
Updated 2008/06/19
How to get Windows Media Centre to play AVI files on x32 & x64 systems.
How to get AVI files to play on Windows Media Centre on x32 & x64 systems.
Solution
1st Uninstall all codecs first.
2nd Then use this codec cleaner
Free-Codecs.com :: Download Vidc.Cleaner 09.03.2004 : If you don't see all codecs in VirtualDub, VirtualdubMod or other programs try Vidc.Cleaner
3rd And now reinstall the codecs. Use these
VistaCodecs x64Components Download - Softpedia
There you go!
All tried & trusted.
All the Best Trax1963
Old 06-19-2008   #14 (permalink)
x64 Home Premium
Or simply use the latest version of VideoLAN - Free Software and Open Source video streaming solution for every OS! as your video player, it's freeware and has all the codecs you need built in.
Old 06-19-2008   #15 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
But, see, Zoloft, VLC is *not* MCE - hence the problem.
Old 08-11-2008   #16 (permalink)
Vista Ultimate 64 bit
Hey guys -
I think this problem is much simpler than you're making it out to be (even with the 3 step process earlier in the thread). I realize I'm a little late to the discussion, but if anyone is going nuts over this still, here's a much easier and simpler explanation and fix. Definitely throw out all the codec programs you have installed (worst case, get that codec cleaner, but most codec programs have an uninstall). Step 2 - download a 64 codec program (again, I'm almost with you guys - and btw, ffdshow now has a 64 bit experimental codec program that works great... i have it as my SOLE codec program). Step 3 - DISABLE 'download codecs automatically' from the (tools-> options) menu in windows media player. Done. Finished. And step 3 is critical - I tried playing videos from step 2 to no avail, I did step 3 and they work like a charm. Hope that helps!!!
Old 08-11-2008   #17 (permalink)
As I replied to you in another post, I have the VCP by shark007, and the x64 components, and WiMP is set to download automatically - and I watched 3 hours of DivX encoded anime today alone.
Old 11-09-2008   #18 (permalink)
Vista Ultimate x64
I've tried all the steps listed above and I still cannot view .avi videos. I can hear the audio with WMP11 or VLC, but no video.
I've tried VistaCodecs with x64, the K-lite x64 pack, the VideoLAN VLC program, and even a few Vista 32 bit codec packs, but nothing worked. I made sure to uninstall each codec pack and run the cleaner program before each new install. I even ran registry cleaners and rebooted before each install, but still can't get .avi to display.
I've got the latest drivers for my video and soundcard and the latest firmware for the mobo.
Any other ideas?
Old 11-10-2008   #19 (permalink)
Mojave Ultimate x64
Are you sure you are running the 64 bit version of WMP, keep in mind both are installed with x64.
Just another point I'd like to make about "AVI" files as most people seem a little confused about it. AVI files are NOT a format, they are a container. An AVI file could contain different audio and video formats. For example one AVI file the video could be encoded in Dixv with audio in mp3 format. Another video could have the video in Intel Indeo and the audio in AC3, etc. So when an "AVI" file is not playing properly you'll need to narrow down which codec you are missing.
There is an application called GSpot that will help you with this.
GSpot Codec Information Appliance
Old 11-10-2008   #20 (permalink)
Vista Ultimate x64
Yes, I'm sure. I was eventually able to sort it out by installing an old Indeo codec that could play IV50 files with WMP11. Can't get them to play with VLC though.
Media Center with 64bit Os Media Center
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
Setup fails for Windows Media Center 64bit Media Center
Having Trouble with Media Center n Nero Vista General
Trouble recording television with Windows Media Center Vista music pictures video
