| home premium vista (64bit) | Media Center (64bit) (avi) trouble hello will trying to play (avi) movies on Windows Media Center (64bit) i get a error that one or more codes are missing to play the video? now today i tryed it and i get the audio but still no video ? anyone no a fix or work around for this? the (avi)'s work fine with media player but not Media Center? thank you very much for your time... scrooge |
| Vista X64 Ulitmate & Vista X86 Ulitmate | Re: Media Center (64bit) (avi) trouble hello will trying to play (avi) movies on Windows Media Center (64bit) i get a error that one or more codes are missing to play the video? now today i tryed it and i get the audio but still no video ? anyone no a fix or work around for this? the (avi)'s work fine with media player but not Media Center? thank you very much for your time... scrooge codec cleaner : http://www.free-codecs.com/download_...hp?d=460&s=268 new codec pack : Here |
| home premium vista (64bit) | Re: Media Center (64bit) (avi) trouble ok will i thank you for the info but i didn't see anything about code cleaner on the site? as for the new code pack after downloading it when trying to run it i just get ( unspecified error ) ? but i did find that i can play mpeg and some others . so it just has to do with (avi) .i tryed uninstalling divx and reinstalling it but no go. also (avi)'s played fine when i used the 32bit vista again thank you scrooge |
| home premium vista (64bit) | Re: Media Center (64bit) (avi) trouble hey AZ93Civic i was able to find the code you said about on another site and it installed and all works fine . avi's play now . thanks again for all your help .... scrooge |
| Vista x64 | Re: Media Center (64bit) (avi) trouble Install Vista Codec Pack from the msfn forums and then the x64 components... It will work out nicely... Vista Codec Package Homepage It works! I like it.. and shark.. is always updating.. and trying to please everyone.. He deserves a donation! |
| | #6 (permalink) |
| Vista Ultimate x64, Windows XP Pro SP2 | Re: Media Center (64bit) (avi) trouble I would highly advise using KLC Codec pac. It will have anything and everything you will ever need. Trust me you will not be disappointed. http://www.softpedia.com/get/Multime...dec-Pack.shtml |
| | #7 (permalink) |
| Vista Home Premium 64Bit SP1 | Re: Media Center (64bit) (avi) trouble I have installed the vista codec packages and can watch avi files in media center but now everytime i try to do anything in dvd maker or video maker they crash. posts on other forums have suggested that this is do to the codec package. I uninstalled the codec package i was able to use video maker again. Is there any way i can have both? |
| | #8 (permalink) |
| Windows 7 Ultimate x64 | Re: Media Center (64bit) (avi) trouble Try just installing ffdshow:- FFDSHOW rev. 610 (20061201) (open source) |
| | #9 (permalink) |
| Vista Home Premium 64Bit SP1 | Re: Media Center (64bit) (avi) trouble Tried installing ffdshow but could not watch avi files in media center when that was installed. Any more suggestions? |
| | #10 (permalink) |
| Vista x64 Ultimate | Re: Media Center (64bit) (avi) trouble I assume you have the COM error, its caused by either Nero 7.7 or the FFD Show codec. Uninstall your codecs and start again, use codec cleaner then install Vista Codec Pack and Vista x64 codec. Try making media player 64 your default player otherwise, you have to click 'Programs\VistaCodecs\64bit Tools\Set Default Media Player' after installing the codec packs. If you get the Com error when generating thumbnails try updating your ffs show codecs. Media usees either 32 bit or 64 bit codecs and the player, whichever you have as the default, you need 64bit codec for the 64but player If this doesnt work try the |
| Media Center with 64bit Os | Media Center | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
| Setup fails for Windows Media Center 64bit | Media Center | |||
| Having Trouble with Media Center n Nero | Vista General | |||
| Trouble recording television with Windows Media Center | Vista music pictures video | |||
