| Ultimate x64 | Ultimate x64 bit problems At the moment I have no Office because I was advised when Word 2003 would crash on start and have to be restarted in safe mode to uninstall and reinstall it. Now I can't get it loaded at all. My very expensice IT guy spent 2 hours and gave up the HP people (this is a brand new laptop) said Vista isn't compatible with Office Pro 2000 which we upgraded from... I have 8 computers running 2003... The other issue is that when I click on a message in hotmail it crashes. No message, just a freeze. What a hassle - I have no Outlook because of problem 1 and no hotmail because of problem 2. Wish I'd been warned... I guess I really was - all those HP machines with extra cost to be 'downgraded' to XP. Suggestions MOST appreciated! |
| Vista Ultimate x64 | Re: Ultimate x64 bit problems I had nothing but problems with Outlook 2007 in Vistax64. Office 2007 and Vistax64 do not play well together at all. |
| Ultimate x64 | Re: Ultimate x64 bit problems were you able to use Office 2003? That's what I'm trying to load. Your warning does make me think that just shoveling out the $$ for 2007 is not the solution... what a hassle. Last edited by johngalt; 11-30-2008 at 02:29 AM.. Reason: changed Oddice to Office |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Ultimate x64 bit problems Hi Margi, I am running Vista x64 Ultimate and I have had no problems running Office 2003 or 2007. Pooch |
| Ultimate x64 SP2 | Re: Ultimate x64 bit problems |
| | #6 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Ultimate x64 bit problems Although I cannot say about Outlook '07 as I do not use it, I am using Office 2007 (Word, Excel, PowerPoint, and a couple of other things) in Vista Ultimate x64 SP1 without a hitch. |
| | #7 (permalink) |
| Ultimate x64 | Re: Ultimate x64 bit problems Well, HP thinks it's the way my IT company setup the permissions, the IT company thinks not... with 2 free hours a month and then $175/hr thereafter it gets tricky. Which makes it hard to know if the problem will be solved by upgrading to Office 2007. |
| Problems with Ultimate 64bit | General Discussion | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| problems with vista ultimate | Vista General | |||
| Ultimate Audio Problems | Vista General | |||
| VISTA Ultimate Problems | Vista General | |||
