| Vista | Need help with Vista and Outlook 2007 Hyperlink problems My hyperlinks in my emails were working fine until yesterday when I decided to give Google Chrome a try. I didn't like it so I went through the correct process of deleting it. After deleting it, when I try to click on a hyperlink to go to a website or even within other Office programs and my Vista links to go online, I get an error message that says "This operation has been canceled due to restrictions in effect on this computer. Please contact your administrator." Well, I am the administrator on this computer. I did a restore and it still did not fix it. Someone please help me get it fixed and tell me what is wrong with it. It is driving me crazy! Thanks, Stephanie |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: Need help with Vista and Outlook 2007 Hyperlink problems Hi Stephanie and welcome to Vista Forums ![]() Have a look here Default Programs - Program Default Associations and make sure that all your programs have their defaults. |
| Vista | Re: Need help with Vista and Outlook 2007 Hyperlink problems I did this several times but it does not fix the problem |
| Vista Home Premium x64 | Re: Need help with Vista and Outlook 2007 Hyperlink problems Have you tried running an Office repair? |
| Vista | Re: Need help with Vista and Outlook 2007 Hyperlink problems Yes, I did the repair and it still continues. I even uninstalled and reinstalled Office and still having the same issue. |
| | #6 (permalink) |
| Vista Home Premium x64 | Re: Need help with Vista and Outlook 2007 Hyperlink problems I was able to duplicate and repair the issue. (Using Vista 32bit) It involves alot of reg editing. I'll post again when I get it all together. |
| | #7 (permalink) |
| Vista | Re: Need help with Vista and Outlook 2007 Hyperlink problems That would be great. I did do a registry scan and it stated that I had over 1100 errors in my registry. Anything you can figure out is greatly appreciated. |
| | #8 (permalink) |
| Vista Home Premium x64 | Re: Need help with Vista and Outlook 2007 Hyperlink problems [HKEY_CLASSES_ROOT\.htm] & [HKEY_CLASSES_ROOT\.html] Change Default to htmlfile [HKEY_CLASSES_ROOT\.shtml] Change Default to shtmlfile [HKEY_CLASSES_ROOT\ftp\DefaultIcon] & [HKEY_CLASSES_ROOT\http\DefaultIcon] & [HKEY_CLASSES_ROOT\https\DefaultIcon] Change Default to %SystemRoot%\system32\url.dll,0 [HKEY_CLASSES_ROOT\ftp\shell\open\command] Change Default to "C:\Program Files\Internet Explorer\iexplorer.exe" %1 [HKEY_CLASSES_ROOT\http\shell\open\command] & [HKEY_CLASSES_ROOT\https\shell\open\command] Change Default to "C:\Program Files\Internet Explorer\iexplorer.exe" -nohome [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared\HTML] Change KnownIDs to htmlfile Remove -[HKEY_CLASSES_ROOT\.xht] -[HKEY_CLASSES_ROOT\.xhtml] -[HKEY_CLASSES_ROOT\ChromeHTML] -[HKEY_CLASSES_ROOT\CLSID\{42042206-2D85-11D3-8CFF-005004838597}\Old Icon\ChromeHTML] -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.shtml\UserChoice] -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xht\UserChoice] -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xhtml\UserChoice] Remove the ChromeHTML entry from -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.htm\OpenWithProgids] -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.html\OpenWithProgids] -[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.shtml\OpenWithProgids] This is what fixed it on my test system which is 32bit. Haven't tried it on a 64bit one. |
| | #9 (permalink) |
| Vista | Re: Need help with Vista and Outlook 2007 Hyperlink problems Thank you! |
| | #10 (permalink) |
| Vista Home premium 32bit | Re: Need help with Vista and Outlook 2007 Hyperlink problems I have the exact problem as above, and have been following the replies. I find all of the items under the remove items and none of the items requiring changes. I have my current version of the registry saved and also on form 10/2008. What do you recommend? |
| Error message with hyperlink in Outlook 2007 | Microsoft Office | |||
| Can't Follow Hyperlink in Outlook 2007 Message | Vista account administration | |||
| outlook 2007 in vista problems | Vista performance & maintenance | |||
| problems with Outlook 2007 in Vista | Vista General | |||
| RE: problems with Outlook 2007 in Vista | Vista General | |||
