WPF: Extending the list view (problem using extended object)
  1. #1
    Griff Guest
    I have a window with multiple ListViews in them.
    When someone right-clicks on any of the listview items, then I want a
    context menu to appear and one of the options is to copy the data displayed
    to the clipboard.
    For a single listView this is simple - I just use the right-mouse-click
    event. However, as said, I've loads of these listViews and more will be
    added in future, so I don't want to keep creating event handlers for every
    instance.
    So, I decided to go down the inheritance route.
    I created a Class called "ListViewExtClass" which inherits from the
    ListView. I changed the on-right-mouse-click event so that it has the
    necessary code. Now to use it.
    In the XAML <Window/> element, I tried to add the xmlns:local definition.
    When I type in "xmlns:local=" it then gives me a list of options....one of
    which is my project. I select it, so I now end up with
    'xmlns:local="clr-namespace:MyProjectName" '. The only problem is that this
    now displays with a squiggle under it. This expands to say "Assembly
    'MyProjectName' was not found. Verify that you are not missing an assembly
    reference. Also, verify that your project and all reference assemblies have
    been built".
    There are no DLLs etc, so everything is "within" the EXE.
    I clicked on "MyProject" and went to the References tab. In the lower
    listview, I found "MyApplicationName" in the list, but it was unticked. I
    ticked it, but this has not solved the problem. I reversed this change.
    It's something trivial I'm sure, but don't know what it is. All help most
    appreciated.
    Thanks
    Griff
  2. #2
    Karsten Schlender Guest
    Re: WPF: Extending the list view (problem using extended object)
    I know this problem in VS 2005, but there it is a mere designer issue,
    compilation should be possible.
    Does this apply to you?
    Karsten
    > to the clipboard.
    > instance.
    > been built".
    > appreciated.
    > Thanks
    > Griff
  3. #3
    Griff Guest
    Hi Karsten
    Unfortunately not...
    If I create a <ListView Name="abc"/> then this can be found in the code:
    me.abc
    However, if I create <local:ListViewExtended Name="abc"/> then "me.abc"
    errors saying that "abc" is unknown.
    Griff
  4. #4
    Griff Guest
  5. #5
    Radek Cerny Guest
    try use x:Name="abc". It might be getting its namespaces confused.
    "Griff" <GriffithsJ_520@xxxxxx> wrote in message
    news:%23xzo11TeIHA.1164@xxxxxx
    > Hi Karsten
    > me.abc
    > Griff
WPF: Extending the list view (problem using extended object) problems?
Extending C: problem. Please help. battle69 General Discussion 2 04 Feb 2010
Monitors cloning, but want extended view. techdummy Graphic cards 2 07 Sep 2009
Sync Center - "Extended Tiles" view option not available Mesquire Vista General 1 26 Aug 2008
Extended Tiles View Perry Diels Vista General 1 23 Aug 2007
Extended Tiles View Perry Diels Vista file management 1 23 Aug 2007
