| | separate long test from unit tests in vsts Hello all, I am used to work with NUnit where I can very easily separate slow tests from fast tests. I simply create two projects: AcceptanceTests and UnitTests. If I only want to execute unittests I run that project only. How can I achieve this in VSTS with the new artifacts like testrunconfig, vsmdi-files and testlists? Thanks in advance! /Rasmus |
| Unit Test Software | .NET General | |||
| How to unit test a Dataset? | .NET General | |||
| Unit Testing - The Merit of Writing Tests First is Questioned | .NET General | |||
