Vista - system.web.extensions
Old 03-03-2008   #1 (permalink)
Ron
Trying to deploy on SBS2003 server an app developed in Visual Studio 2008
(which runs fine on local machine), I get a message about an unknown type:
sectionGroup name="system.web.extensions"
type="System.Web.Configuration.SystemWebExtensionsSectionGroup,
System.Web.Extensions, Version=3.5.0.0, Culture=neutral,
PublicKeyToken=31BF3856AD364E35">
Checking the GAC, there is no such type installed on machine. I assume this
is either Ajax or .net 3.5 related (which I believe VS2008 incorporates
automatically)? Is this just a matter of installing 3.5 on the server?
Old 03-03-2008   #2 (permalink)
Jon Skeet [C# MVP]
Re: system.web.extensions
Yes, installing .NET 3.5 will install the assembly into the GAC, I
believe.
Jon Skeet - <skeet@xxxxxx>
http://www.pobox.com/~skeet Blog: http://www.msmvps.com/jon.skeet
World class .NET training in the UK: http://iterativetraining.co.uk
Old 03-10-2008   #3 (permalink)
Madhur
Jon Skeet [C# MVP] wrote:
>> 2008 (which runs fine on local machine), I get a message about an
>> unknown type:
>> assume this is either Ajax or .net 3.5 related (which I believe
>> VS2008 incorporates automatically)? Is this just a matter of
> believe.
Yes, System.Web.Extensions are particularly used by ASP.NET AJAX Extensions.
Madhur
http://madhurahuja.blogspot.com
efw file extensions Live Mail
eml extensions Vista mail
.doc file extensions Vista General
File Extensions Vista installation & setup
