Vista - Old Hp printer deskjet 722C pls help me install a printer driver
Old 03-06-2008   #1 (permalink)
Del
Hello I need help I have a 1998 hp and have installed windows xp I can't seem
to install a printer driver to make my computer communicate with my old hp
722c
printer..I've installed the ones from the internet and nothing seems to
work...do I need a HP cd or a different electrical cord..the printer works
fine I hope I can continue to use this printer can someone help me pls thanks
Del
Old 03-06-2008   #2 (permalink)
PvdG42
Re: Old Hp printer deskjet 722C pls help me install a printer driver
"Del" <Del@xxxxxx> wrote in message
news:40D521F3-59A6-4D44-9AB5-A335F5323435@xxxxxx
> seem
> hp
> 722c
> thanks
> Del
Did you follow these instructions?
http://h10025.www1.hp.com/ewfrf/wc/d...=57565&lang=en
Installing HP Deskjet 722C printer drivers on a Vista machine ? Vista print fax & scan
HP Deskjet 722C Networked Vista print fax & scan
Can't install HP printer driver Vista print fax & scan
RE: vista hp printer driver won't install Vista General
Can't install printer driver Vista print fax & scan
