Vista - Difference between VS 2005 and VS 2005 Express
Old 03-08-2008   #1 (permalink)
Curious
What's the difference between Visual Studio 2005 and Visual Studio
2005 Express?
I want to start a project on multi-threading in .NET. Will using
Visual Studio 2005 Express be sufficient?
Old 03-08-2008   #2 (permalink)
PvdG42
Re: Difference between VS 2005 and VS 2005 Express
"Curious" <fir5tsight@xxxxxx> wrote in message
news:78c1c293-cf6c-4673-88d3-955060427f84@xxxxxx
> 2005 Express?
Which Express Edition? VB, VC, VC#, Web?
As the express editions use the full .NET Framework class hierarchy, you
should not encounter problems using the classes that support multithreading.
Old 03-08-2008   #3 (permalink)
Curious
> As the express editions use the full .NET Framework *class hierarchy, you
It's C#.NET. I want to do a lot of multi-threading.
Old 03-08-2008   #4 (permalink)
Dick Grier
No difference, with respect to the .NET framework, for threading.
Express does not support (for example) creating projects for Compact
Framework devices, which requires Standard Edition or higher -- just as one
limitaton.
Richard Grier, MVP
Hard & Software
Author of Visual Basic Programmer's Guide to Serial Communications, Fourth
Edition,
ISBN 1-890422-28-2 (391 pages, includes CD-ROM). July 2004, Revised March
2006.
See www.hardandsoftware.net for details and contact information.
Old 03-09-2008   #5 (permalink)
Curious
Thanks for the valuable advice!
SQL 2005 Express in a Vista x64 Software
Can I Run SQL 2005 Express on 64-bit OS Virtual Server
Data Not Displaying SQL Express 2005 VB Script
VWD 2005 Express ? VB Script
Installing Visual Studio 2005 Std Ed, SQL Server 2005 Expr./Compac Vista installation & setup
