| Guest | Low Refresh Rate I using a new laptop running Vista and have Nvidia GeForce 7600 graphics card. I'm trying to connect my TV to this computer using Svideo. It has worked in the past however I must have changed a setting somewhere? On my second computer with Xp it all connects right! So it's all connected but the display on the TV is just rolling lines as though it is scrambled. On the monitor setting, the refresh rate is stuck on 25Hertz Interlaced. Is there a way of forcing a higher refresh rate? or is there another setting I need to change? I have been seraching for months for an answer to this question. HELP PLEASE! |
| Guest | Re: Low Refresh Rate Try posting your question to a newsgroup with "Windows" in the description. This is a .Net programming newsgroup. RobinS. --------------------------------- "Brett" <Brett@xxxxxx> wrote in message news:2A12523E-ED28-42B8-8C53-2A306B1F2B67@xxxxxx Quote: >I using a new laptop running Vista and have Nvidia GeForce 7600 graphics > card. I'm trying to connect my TV to this computer using Svideo. It has > worked in the past however I must have changed a setting somewhere? On my > second computer with Xp it all connects right! > > So it's all connected but the display on the TV is just rolling lines as > though it is scrambled. On the monitor setting, the refresh rate is stuck > on > 25Hertz Interlaced. > > Is there a way of forcing a higher refresh rate? or is there another > setting I need to change? > > I have been seraching for months for an answer to this question. HELP > PLEASE! |
| Low refresh rate | Vista General | |||
| Refresh rate | Vista performance & maintenance | |||
| Refresh Rate | Vista hardware & devices | |||
| Nivada refresh rate | Vista hardware & devices | |||
