| | SQLMetal - Problem generating VB from DBML I have a test DBML file:- <?xml version="1.0" encoding="utf-8"?> <Database Name="myDB" EntityNamespace="MyEntNS" ContextNamespace="MyConNs" Class="DBdc" xmlns="http://schemas.microsoft.com/linqtosql/dbml/2007"> <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> <Type Name="PARENTTABLE"> <Column Name="keycol1" Member="keycol1" Type="System.Decimal" DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> <Column Name="keycol2" Member="keycol2" Type="System.Decimal" DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> <Column Name="keycol3" Member="keycol3" Type="System.String" DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> <Association Name="fk_1064" Member="fkCHILDTABLE" ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" Type="CHILDTABLE" DeleteRule="NO ACTION" /> </Type> </Table> <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> <Type Name="CHILDTABLE"> <Column Name="main_id" Member="publish_id" Type="System.String" DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" DbType="Decimal(10,0)" CanBeNull="true" /> <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" DbType="Decimal(10,0)" CanBeNull="true" /> <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" DbType="VarChar(10)" CanBeNull="true" /> <Association Name="fk_1064" Member="pkPARENTTABLE" ThisKey="fkeycol3,fkeycol1,fkeycol2" OtherKey="keycol3,keycol1,keycol2" Type="PARENTTABLE" IsForeignKey="true" /> </Type> </Table> </Database> Note that the order of the columns on the PARENTTABLE are listed correctly as keycol1, keycol2, keycol3, but the promary key on the table is actually keycol3, keycol1, keycol2. The association elements do use the correct primary key sequences. However, when I generate the VB for this DBML, it gets it wrong.. see the text below highlighted in red. <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ Public Property pkPARENTTABLE() As PARENTTABLE Get Return Me._pkPARENTTABLE.Entity End Get Set Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity If ((Object.Equals(previousValue, value) = false) _ OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) Then Me.SendPropertyChanging If ((previousValue Is Nothing) _ = false) Then Me._pkPARENTTABLE.Entity = Nothing previousValue.fkCHILDTABLE.Remove(Me) End If Me._pkPARENTTABLE.Entity = value If ((value Is Nothing) _ = false) Then value.fkCHILDTABLE.Add(Me) Me._fkeycol3 = value.keycol1 Me._fkeycol1 = value.keycol2 Me._fkeycol2 = value.keycol3 Else Me._fkeycol3 = CType(Nothing, String) Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) End If Me.SendPropertyChanged("pkPARENTTABLE") End If End Set End Property Is there something wrong with the DBML or is it a bug in SQLMetal ? (this is using the RTM (1.00.21022) version of SQLMetal) -- Adrian |
| | RE: SQLMetal - Problem generating VB from DBML Hi Adrian, As for the DBML file you provided, how did you generate it? For general validation, you can use the DBML schemas to validate the DBML to see whether there is any XML schema specific errors. Here is the MSDN reference about this: #How to: Validate DBML and External Mapping Files (LINQ to SQL) http://msdn2.microsoft.com/en-us/library/bb882675.aspx if there doesn't exist such error. I think there may have some certain database related things cause potential problems. Sincerely, Steven Cheng Microsoft MSDN Online Support Lead Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. ================================================== This posting is provided "AS IS" with no warranties, and confers no rights. -------------------- Quote: >Reply-To: "Adrian" <apparker@xxxxxx> >From: "Adrian" <apparker@xxxxxx> >Subject: SQLM Quote: >I have a test DBML file:- ><?xml version="1.0" encoding="utf-8"?> ><Database Name="myDB" EntityNamespace="MyEntNS" ContextNamespace="MyConNs" Quote: > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> > <Type Name="PARENTTABLE"> > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" Quote: > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" Quote: > <Column Name="keycol3" Member="keycol3" Type="System.String" Quote: > <Association Name="fk_1064" Member="fkCHILDTABLE" Type="CHILDTABLE" DeleteRule="NO ACTION" /> Quote: > </Type> > </Table> > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> > <Type Name="CHILDTABLE"> > <Column Name="main_id" Member="publish_id" Type="System.String" Quote: > <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" Quote: > <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" Quote: > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" Quote: > <Association Name="fk_1064" Member="pkPARENTTABLE" Type="PARENTTABLE" IsForeignKey="true" /> Quote: > </Type> > </Table> ></Database> >Note that the order of the columns on the PARENTTABLE are listed correctly keycol3, keycol1, keycol2. The association elements do use the correct primary key sequences. However, when I generate the VB for this DBML, it gets it wrong.. see the text below highlighted in red. Quote: > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", Quote: > Public Property pkPARENTTABLE() As PARENTTABLE > Get > Return Me._pkPARENTTABLE.Entity > End Get > Set > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity > If ((Object.Equals(previousValue, value) = false) _ > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) Then > Me.SendPropertyChanging > If ((previousValue Is Nothing) _ > = false) Then > Me._pkPARENTTABLE.Entity = Nothing > previousValue.fkCHILDTABLE.Remove(Me) > End If > Me._pkPARENTTABLE.Entity = value > If ((value Is Nothing) _ > = false) Then > value.fkCHILDTABLE.Add(Me) > Me._fkeycol3 = value.keycol1 > Me._fkeycol1 = value.keycol2 > Me._fkeycol2 = value.keycol3 > Else > Me._fkeycol3 = CType(Nothing, String) > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) > End If > Me.SendPropertyChanged("pkPARENTTABLE") > End If > End Set > End Property >Is there something wrong with the DBML or is it a bug in SQLMetal ? >(this is using the RTM (1.00.21022) version of SQLMetal) >-- >Adrian > |
| | Re: SQLMetal - Problem generating VB from DBML Steven, The dbml file is one we 'adjust' from the normal one generated by SQLMetal.. we have to 'fix' some of the Member entries as they're badly named by sqlmetal. Followd your link and tried to validate, but when I go to the properties window in VS, it doesn't give me a 'Schema' property to select.. it just gives.. Access: Public Base Class: System.Data.Linq.DataContext +Connection Context Namespace: MyConNS Entity Namespace: MyEntNs Inheritance Modifier: (None) Name: DBdc Serialization Mode: None Anyway, thinking about it, it does generate the VB, it just gets some columns switched around. As I said, it seems like it's not using the order of the ThisKey and OtherKey when creating the code, but is taking the order of the columns in the <column> elements. ""Steven Cheng"" <stcheng@xxxxxx> wrote in message news:SBISRf$hIHA.4672@xxxxxx | Hi Adrian, | | As for the DBML file you provided, how did you generate it? | | For general validation, you can use the DBML schemas to validate the DBML | to see whether there is any XML schema specific errors. Here is the MSDN | reference about this: | | #How to: Validate DBML and External Mapping Files (LINQ to SQL) | http://msdn2.microsoft.com/en-us/library/bb882675.aspx | | if there doesn't exist such error. I think there may have some certain | database related things cause potential problems. | | Sincerely, | | Steven Cheng | | Microsoft MSDN Online Support Lead | | | Delighting our customers is our #1 priority. We welcome your comments and | suggestions about how we can improve the support we provide to you. Please | feel free to let my manager know what you think of the level of service | provided. You can send feedback directly to my manager at: | msdnmg@xxxxxx. | | ================================================== | This posting is provided "AS IS" with no warranties, and confers no rights. | | -------------------- | >Reply-To: "Adrian" <apparker@xxxxxx> | >From: "Adrian" <apparker@xxxxxx> | >Subject: SQLM | | >I have a test DBML file:- | ><?xml version="1.0" encoding="utf-8"?> | ><Database Name="myDB" EntityNamespace="MyEntNS" ContextNamespace="MyConNs" | Class="DBdc" xmlns="http://schemas.microsoft.com/linqtosql/dbml/2007"> | > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> | > <Type Name="PARENTTABLE"> | > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" | DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" | DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | > <Column Name="keycol3" Member="keycol3" Type="System.String" | DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | > <Association Name="fk_1064" Member="fkCHILDTABLE" | ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" | Type="CHILDTABLE" DeleteRule="NO ACTION" /> | > </Type> | > </Table> | > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> | > <Type Name="CHILDTABLE"> | > <Column Name="main_id" Member="publish_id" Type="System.String" | DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | > <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" | DbType="Decimal(10,0)" CanBeNull="true" /> | > <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" | DbType="Decimal(10,0)" CanBeNull="true" /> | > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" | DbType="VarChar(10)" CanBeNull="true" /> | > <Association Name="fk_1064" Member="pkPARENTTABLE" | ThisKey="fkeycol3,fkeycol1,fkeycol2" OtherKey="keycol3,keycol1,keycol2" | Type="PARENTTABLE" IsForeignKey="true" /> | > </Type> | > </Table> | ></Database> | >Note that the order of the columns on the PARENTTABLE are listed correctly | as keycol1, keycol2, keycol3, but the promary key on the table is actually | keycol3, keycol1, keycol2. The association elements do use the correct | primary key sequences. However, when I generate the VB for this DBML, it | gets it wrong.. see the text below highlighted in red. | > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", | ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ | > Public Property pkPARENTTABLE() As PARENTTABLE | > Get | > Return Me._pkPARENTTABLE.Entity | > End Get | > Set | > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity | > If ((Object.Equals(previousValue, value) = false) _ | > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) Then | > Me.SendPropertyChanging | > If ((previousValue Is Nothing) _ | > = false) Then | > Me._pkPARENTTABLE.Entity = Nothing | > previousValue.fkCHILDTABLE.Remove(Me) | > End If | > Me._pkPARENTTABLE.Entity = value | > If ((value Is Nothing) _ | > = false) Then | > value.fkCHILDTABLE.Add(Me) | > Me._fkeycol3 = value.keycol1 | > Me._fkeycol1 = value.keycol2 | > Me._fkeycol2 = value.keycol3 | > Else | > Me._fkeycol3 = CType(Nothing, String) | > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) | > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) | > End If | > Me.SendPropertyChanged("pkPARENTTABLE") | > End If | > End Set | > End Property | >Is there something wrong with the DBML or is it a bug in SQLMetal ? | >(this is using the RTM (1.00.21022) version of SQLMetal) | >-- | >Adrian | > | |
| | Re: SQLMetal - Problem generating VB from DBML Hi Adrian, For the DBML document you mentioned, I've also tested it. Yes, if we keep the three primary columns and their order always as 1, 2, 3 in all places, it will generate code as expected. However, if we change the order as below(in your customized DBML): ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" the code it generate does seem different between the columns order in DBML. I'll do some further research to see whether there is anything which can control this. Sincerely, Steven Cheng Microsoft MSDN Online Support Lead Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. This posting is provided "AS IS" with no warranties, and confers no rights. -------------------- Quote: >Reply-To: "Adrian" <apparker@xxxxxx> >From: "Adrian" <apparker@xxxxxx> >References: <uPcn4ddhIHA.748@xxxxxx> Quote: >Subject: Re: SQLMetal - Problem generating VB from DBML >Date: Mon, 17 Mar 2008 10:50:34 -0000 >Steven, > >The dbml file is one we 'adjust' from the normal one generated by Quote: >we have to 'fix' some of the Member entries as they're badly named by >sqlmetal. > >Followd your link and tried to validate, but when I go to the properties >window in VS, it doesn't give me a 'Schema' property to select.. it just >gives.. > >Access: Public >Base Class: System.Data.Linq.DataContext >+Connection >Context Namespace: MyConNS >Entity Namespace: MyEntNs >Inheritance Modifier: (None) >Name: DBdc >Serialization Mode: None > > >Anyway, thinking about it, it does generate the VB, it just gets some >columns switched around. As I said, it seems like it's not using the Quote: >of the ThisKey and OtherKey when creating the code, but is taking the Quote: >of the columns in the <column> elements. > > > > >""Steven Cheng"" <stcheng@xxxxxx> wrote in message >news:SBISRf$hIHA.4672@xxxxxx >| Hi Adrian, >| >| As for the DBML file you provided, how did you generate it? >| >| For general validation, you can use the DBML schemas to validate the DBML >| to see whether there is any XML schema specific errors. Here is the MSDN >| reference about this: >| >| #How to: Validate DBML and External Mapping Files (LINQ to SQL) >| http://msdn2.microsoft.com/en-us/library/bb882675.aspx >| >| if there doesn't exist such error. I think there may have some certain >| database related things cause potential problems. >| >| Sincerely, >| >| Steven Cheng >| >| Microsoft MSDN Online Support Lead >| >| >| Delighting our customers is our #1 priority. We welcome your comments and >| suggestions about how we can improve the support we provide to you. Quote: >| feel free to let my manager know what you think of the level of service >| provided. You can send feedback directly to my manager at: >| msdnmg@xxxxxx. >| >| ================================================== >| This posting is provided "AS IS" with no warranties, and confers no >rights. >| >| -------------------- >| >Reply-To: "Adrian" <apparker@xxxxxx> >| >From: "Adrian" <apparker@xxxxxx> >| >Subject: SQLM >| >| >I have a test DBML file:- >| ><?xml version="1.0" encoding="utf-8"?> >| ><Database Name="myDB" EntityNamespace="MyEntNS" >ContextNamespace="MyConNs" >| Class="DBdc" xmlns="http://schemas.microsoft.com/linqtosql/dbml/2007"> >| > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> >| > <Type Name="PARENTTABLE"> >| > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" >| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >| > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" >| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >| > <Column Name="keycol3" Member="keycol3" Type="System.String" >| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >| > <Association Name="fk_1064" Member="fkCHILDTABLE" >| ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" >| Type="CHILDTABLE" DeleteRule="NO ACTION" /> >| > </Type> >| > </Table> >| > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> >| > <Type Name="CHILDTABLE"> >| > <Column Name="main_id" Member="publish_id" Type="System.String" >| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >| > <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" >| DbType="Decimal(10,0)" CanBeNull="true" /> >| > <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" >| DbType="Decimal(10,0)" CanBeNull="true" /> >| > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" >| DbType="VarChar(10)" CanBeNull="true" /> >| > <Association Name="fk_1064" Member="pkPARENTTABLE" >| ThisKey="fkeycol3,fkeycol1,fkeycol2" OtherKey="keycol3,keycol1,keycol2" >| Type="PARENTTABLE" IsForeignKey="true" /> >| > </Type> >| > </Table> >| ></Database> >| >Note that the order of the columns on the PARENTTABLE are listed >correctly >| as keycol1, keycol2, keycol3, but the promary key on the table is Quote: >| keycol3, keycol1, keycol2. The association elements do use the correct >| primary key sequences. However, when I generate the VB for this DBML, Quote: >| gets it wrong.. see the text below highlighted in red. >| > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", >| ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ >| > Public Property pkPARENTTABLE() As PARENTTABLE >| > Get >| > Return Me._pkPARENTTABLE.Entity >| > End Get >| > Set >| > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity >| > If ((Object.Equals(previousValue, value) = false) _ >| > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) Then >| > Me.SendPropertyChanging >| > If ((previousValue Is Nothing) _ >| > = false) Then >| > Me._pkPARENTTABLE.Entity = Nothing >| > previousValue.fkCHILDTABLE.Remove(Me) >| > End If >| > Me._pkPARENTTABLE.Entity = value >| > If ((value Is Nothing) _ >| > = false) Then >| > value.fkCHILDTABLE.Add(Me) >| > Me._fkeycol3 = value.keycol1 >| > Me._fkeycol1 = value.keycol2 >| > Me._fkeycol2 = value.keycol3 >| > Else >| > Me._fkeycol3 = CType(Nothing, String) >| > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) >| > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) >| > End If >| > Me.SendPropertyChanged("pkPARENTTABLE") >| > End If >| > End Set >| > End Property >| >Is there something wrong with the DBML or is it a bug in SQLMetal ? >| >(this is using the RTM (1.00.21022) version of SQLMetal) >| >-- >| >Adrian >| > >| > > > |
| | Re: SQLMetal - Problem generating VB from DBML Hi Adrian, I've performed some further research on this issue and consult some other experts on this. Some engineers from dev team told me that this is an by designed behavior of the LINQ DBML generation. currently, it will require you to keep the column orders(in your "ThisKey" and "OtherKey" ) the same as the column sequence in the table schema. Changing the order will make the generated code become mismatch on the column/fields's assignment. Sincerely, Steven Cheng Microsoft MSDN Online Support Lead Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. This posting is provided "AS IS" with no warranties, and confers no rights. -------------------- Quote: >From: stcheng@xxxxxx ("Steven Cheng") >Organization: Microsoft >Date: Mon, 24 Mar 2008 09:34:34 GMT >Subject: Re: SQLMetal - Problem generating VB from DBML Quote: > >Hi Adrian, > >For the DBML document you mentioned, I've also tested it. Yes, if we keep >the three primary columns and their order always as 1, 2, 3 in all Quote: >it will generate code as expected. However, if we change the order as >below(in your customized DBML): > >ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" > >the code it generate does seem different between the columns order in >DBML. I'll do some further research to see whether there is anything which >can control this. > >Sincerely, > >Steven Cheng > >Microsoft MSDN Online Support Lead > > >Delighting our customers is our #1 priority. We welcome your comments and >suggestions about how we can improve the support we provide to you. Please >feel free to let my manager know what you think of the level of service >provided. You can send feedback directly to my manager at: >msdnmg@xxxxxx > >This posting is provided "AS IS" with no warranties, and confers no rights. > > > >-------------------- Quote: >>Reply-To: "Adrian" <apparker@xxxxxx> >>From: "Adrian" <apparker@xxxxxx> >>References: <uPcn4ddhIHA.748@xxxxxx> Quote: >>Subject: Re: SQLMetal - Problem generating VB from DBML >>Date: Mon, 17 Mar 2008 10:50:34 -0000 >>Steven, >> >>The dbml file is one we 'adjust' from the normal one generated by Quote: >>we have to 'fix' some of the Member entries as they're badly named by >>sqlmetal. >> >>Followd your link and tried to validate, but when I go to the properties >>window in VS, it doesn't give me a 'Schema' property to select.. it just >>gives.. >> >>Access: Public >>Base Class: System.Data.Linq.DataContext >>+Connection >>Context Namespace: MyConNS >>Entity Namespace: MyEntNs >>Inheritance Modifier: (None) >>Name: DBdc >>Serialization Mode: None >> >> >>Anyway, thinking about it, it does generate the VB, it just gets some >>columns switched around. As I said, it seems like it's not using the Quote: >>of the ThisKey and OtherKey when creating the code, but is taking the Quote: >>of the columns in the <column> elements. >> >> >> >> >>""Steven Cheng"" <stcheng@xxxxxx> wrote in message >>news:SBISRf$hIHA.4672@xxxxxx >>| Hi Adrian, >>| >>| As for the DBML file you provided, how did you generate it? >>| >>| For general validation, you can use the DBML schemas to validate the Quote: Quote: >>| to see whether there is any XML schema specific errors. Here is the MSDN >>| reference about this: >>| >>| #How to: Validate DBML and External Mapping Files (LINQ to SQL) >>| http://msdn2.microsoft.com/en-us/library/bb882675.aspx >>| >>| if there doesn't exist such error. I think there may have some certain >>| database related things cause potential problems. >>| >>| Sincerely, >>| >>| Steven Cheng >>| >>| Microsoft MSDN Online Support Lead >>| >>| >>| Delighting our customers is our #1 priority. We welcome your comments Quote: Quote: >>| suggestions about how we can improve the support we provide to you. Quote: >>| feel free to let my manager know what you think of the level of service >>| provided. You can send feedback directly to my manager at: >>| msdnmg@xxxxxx. >>| >>| ================================================== >>| This posting is provided "AS IS" with no warranties, and confers no >>rights. >>| >>| -------------------- >>| >Reply-To: "Adrian" <apparker@xxxxxx> >>| >From: "Adrian" <apparker@xxxxxx> >>| >Subject: SQLM >>| >>| >I have a test DBML file:- >>| ><?xml version="1.0" encoding="utf-8"?> >>| ><Database Name="myDB" EntityNamespace="MyEntNS" >>ContextNamespace="MyConNs" >>| Class="DBdc" xmlns="http://schemas.microsoft.com/linqtosql/dbml/2007"> >>| > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> >>| > <Type Name="PARENTTABLE"> >>| > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >>| > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >>| > <Column Name="keycol3" Member="keycol3" Type="System.String" >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >>| > <Association Name="fk_1064" Member="fkCHILDTABLE" >>| ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" >>| Type="CHILDTABLE" DeleteRule="NO ACTION" /> >>| > </Type> >>| > </Table> >>| > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> >>| > <Type Name="CHILDTABLE"> >>| > <Column Name="main_id" Member="publish_id" Type="System.String" >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> >>| > <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" >>| DbType="Decimal(10,0)" CanBeNull="true" /> >>| > <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" >>| DbType="Decimal(10,0)" CanBeNull="true" /> >>| > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" >>| DbType="VarChar(10)" CanBeNull="true" /> >>| > <Association Name="fk_1064" Member="pkPARENTTABLE" >>| ThisKey="fkeycol3,fkeycol1,fkeycol2" OtherKey="keycol3,keycol1,keycol2" >>| Type="PARENTTABLE" IsForeignKey="true" /> >>| > </Type> >>| > </Table> >>| ></Database> >>| >Note that the order of the columns on the PARENTTABLE are listed >>correctly >>| as keycol1, keycol2, keycol3, but the promary key on the table is Quote: >>| keycol3, keycol1, keycol2. The association elements do use the correct >>| primary key sequences. However, when I generate the VB for this DBML, Quote: >>| gets it wrong.. see the text below highlighted in red. >>| > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", >>| ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ >>| > Public Property pkPARENTTABLE() As PARENTTABLE >>| > Get >>| > Return Me._pkPARENTTABLE.Entity >>| > End Get >>| > Set >>| > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity >>| > If ((Object.Equals(previousValue, value) = false) _ >>| > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) Quote: Quote: >>| > Me.SendPropertyChanging >>| > If ((previousValue Is Nothing) _ >>| > = false) Then >>| > Me._pkPARENTTABLE.Entity = Nothing >>| > previousValue.fkCHILDTABLE.Remove(Me) >>| > End If >>| > Me._pkPARENTTABLE.Entity = value >>| > If ((value Is Nothing) _ >>| > = false) Then >>| > value.fkCHILDTABLE.Add(Me) >>| > Me._fkeycol3 = value.keycol1 >>| > Me._fkeycol1 = value.keycol2 >>| > Me._fkeycol2 = value.keycol3 >>| > Else >>| > Me._fkeycol3 = CType(Nothing, String) >>| > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) >>| > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) >>| > End If >>| > Me.SendPropertyChanged("pkPARENTTABLE") >>| > End If >>| > End Set >>| > End Property >>| >Is there something wrong with the DBML or is it a bug in SQLMetal ? >>| >(this is using the RTM (1.00.21022) version of SQLMetal) >>| >-- >>| >Adrian >>| > >>| >> >> >> > |
| | #6 (permalink) |
| | Re: SQLMetal - Problem generating VB from DBML Hi Steven, I've now written a routine to correct the column sequence in the xml to match the actual primary key. The code generates fine now. "Steven Cheng [MSFT]" <stcheng@xxxxxx> wrote in message news QdzKgwjIHA.5204@xxxxxx| Hi Adrian, | | I've performed some further research on this issue and consult some other | experts on this. Some engineers from dev team told me that this is an by | designed behavior of the LINQ DBML generation. currently, it will require | you to keep the column orders(in your "ThisKey" and "OtherKey" ) the same | as the column sequence in the table schema. Changing the order will make | the generated code become mismatch on the column/fields's assignment. | | Sincerely, | | Steven Cheng | | Microsoft MSDN Online Support Lead | | | Delighting our customers is our #1 priority. We welcome your comments and | suggestions about how we can improve the support we provide to you. Please | feel free to let my manager know what you think of the level of service | provided. You can send feedback directly to my manager at: | msdnmg@xxxxxx. | | This posting is provided "AS IS" with no warranties, and confers no rights. | | | -------------------- | >From: stcheng@xxxxxx ("Steven Cheng") | >Organization: Microsoft | >Date: Mon, 24 Mar 2008 09:34:34 GMT | >Subject: Re: SQLMetal - Problem generating VB from DBML | | > | >Hi Adrian, | > | >For the DBML document you mentioned, I've also tested it. Yes, if we keep | >the three primary columns and their order always as 1, 2, 3 in all | places, | >it will generate code as expected. However, if we change the order as | >below(in your customized DBML): | > | >ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" | > | >the code it generate does seem different between the columns order in | >DBML. I'll do some further research to see whether there is anything which | >can control this. | > | >Sincerely, | > | >Steven Cheng | > | >Microsoft MSDN Online Support Lead | > | > | >Delighting our customers is our #1 priority. We welcome your comments and | >suggestions about how we can improve the support we provide to you. Please | >feel free to let my manager know what you think of the level of service | >provided. You can send feedback directly to my manager at: | >msdnmg@xxxxxx | > | >This posting is provided "AS IS" with no warranties, and confers no rights. | > | > | > | >-------------------- | >>Reply-To: "Adrian" <apparker@xxxxxx> | >>From: "Adrian" <apparker@xxxxxx> | >>References: <uPcn4ddhIHA.748@xxxxxx> | ><SBISRf$hIHA.4672@xxxxxx> | >>Subject: Re: SQLMetal - Problem generating VB from DBML | >>Date: Mon, 17 Mar 2008 10:50:34 -0000 | >>Steven, | >> | >>The dbml file is one we 'adjust' from the normal one generated by | >SQLMetal.. | >>we have to 'fix' some of the Member entries as they're badly named by | >>sqlmetal. | >> | >>Followd your link and tried to validate, but when I go to the properties | >>window in VS, it doesn't give me a 'Schema' property to select.. it just | >>gives.. | >> | >>Access: Public | >>Base Class: System.Data.Linq.DataContext | >>+Connection | >>Context Namespace: MyConNS | >>Entity Namespace: MyEntNs | >>Inheritance Modifier: (None) | >>Name: DBdc | >>Serialization Mode: None | >> | >> | >>Anyway, thinking about it, it does generate the VB, it just gets some | >>columns switched around. As I said, it seems like it's not using the | >order | >>of the ThisKey and OtherKey when creating the code, but is taking the | >order | >>of the columns in the <column> elements. | >> | >> | >> | >> | >>""Steven Cheng"" <stcheng@xxxxxx> wrote in message | >>news:SBISRf$hIHA.4672@xxxxxx | >>| Hi Adrian, | >>| | >>| As for the DBML file you provided, how did you generate it? | >>| | >>| For general validation, you can use the DBML schemas to validate the | DBML | >>| to see whether there is any XML schema specific errors. Here is the MSDN | >>| reference about this: | >>| | >>| #How to: Validate DBML and External Mapping Files (LINQ to SQL) | >>| http://msdn2.microsoft.com/en-us/library/bb882675.aspx | >>| | >>| if there doesn't exist such error. I think there may have some certain | >>| database related things cause potential problems. | >>| | >>| Sincerely, | >>| | >>| Steven Cheng | >>| | >>| Microsoft MSDN Online Support Lead | >>| | >>| | >>| Delighting our customers is our #1 priority. We welcome your comments | and | >>| suggestions about how we can improve the support we provide to you. | >Please | >>| feel free to let my manager know what you think of the level of service | >>| provided. You can send feedback directly to my manager at: | >>| msdnmg@xxxxxx. | >>| | >>| ================================================== | >>| This posting is provided "AS IS" with no warranties, and confers no | >>rights. | >>| | >>| -------------------- | >>| >Reply-To: "Adrian" <apparker@xxxxxx> | >>| >From: "Adrian" <apparker@xxxxxx> | >>| >Subject: SQLM | >>| | >>| >I have a test DBML file:- | >>| ><?xml version="1.0" encoding="utf-8"?> | >>| ><Database Name="myDB" EntityNamespace="MyEntNS" | >>ContextNamespace="MyConNs" | >>| Class="DBdc" xmlns="http://schemas.microsoft.com/linqtosql/dbml/2007"> | >>| > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> | >>| > <Type Name="PARENTTABLE"> | >>| > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" | >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | >>| > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" | >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | >>| > <Column Name="keycol3" Member="keycol3" Type="System.String" | >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | >>| > <Association Name="fk_1064" Member="fkCHILDTABLE" | >>| ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" | >>| Type="CHILDTABLE" DeleteRule="NO ACTION" /> | >>| > </Type> | >>| > </Table> | >>| > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> | >>| > <Type Name="CHILDTABLE"> | >>| > <Column Name="main_id" Member="publish_id" Type="System.String" | >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" /> | >>| > <Column Name="fkeycol1" Member="fkeycol1" Type="System.Decimal" | >>| DbType="Decimal(10,0)" CanBeNull="true" /> | >>| > <Column Name="fkeycol2" Member="fkeycol2" Type="System.Decimal" | >>| DbType="Decimal(10,0)" CanBeNull="true" /> | >>| > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" | >>| DbType="VarChar(10)" CanBeNull="true" /> | >>| > <Association Name="fk_1064" Member="pkPARENTTABLE" | >>| ThisKey="fkeycol3,fkeycol1,fkeycol2" OtherKey="keycol3,keycol1,keycol2" | >>| Type="PARENTTABLE" IsForeignKey="true" /> | >>| > </Type> | >>| > </Table> | >>| ></Database> | >>| >Note that the order of the columns on the PARENTTABLE are listed | >>correctly | >>| as keycol1, keycol2, keycol3, but the promary key on the table is | >actually | >>| keycol3, keycol1, keycol2. The association elements do use the correct | >>| primary key sequences. However, when I generate the VB for this DBML, | >it | >>| gets it wrong.. see the text below highlighted in red. | >>| > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", | >>| ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ | >>| > Public Property pkPARENTTABLE() As PARENTTABLE | >>| > Get | >>| > Return Me._pkPARENTTABLE.Entity | >>| > End Get | >>| > Set | >>| > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity | >>| > If ((Object.Equals(previousValue, value) = false) _ | >>| > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) | Then | >>| > Me.SendPropertyChanging | >>| > If ((previousValue Is Nothing) _ | >>| > = false) Then | >>| > Me._pkPARENTTABLE.Entity = Nothing | >>| > previousValue.fkCHILDTABLE.Remove(Me) | >>| > End If | >>| > Me._pkPARENTTABLE.Entity = value | >>| > If ((value Is Nothing) _ | >>| > = false) Then | >>| > value.fkCHILDTABLE.Add(Me) | >>| > Me._fkeycol3 = value.keycol1 | >>| > Me._fkeycol1 = value.keycol2 | >>| > Me._fkeycol2 = value.keycol3 | >>| > Else | >>| > Me._fkeycol3 = CType(Nothing, String) | >>| > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) | >>| > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) | >>| > End If | >>| > Me.SendPropertyChanged("pkPARENTTABLE") | >>| > End If | >>| > End Set | >>| > End Property | >>| >Is there something wrong with the DBML or is it a bug in SQLMetal ? | >>| >(this is using the RTM (1.00.21022) version of SQLMetal) | >>| >-- | >>| >Adrian | >>| > | >>| | >> | >> | >> | > | > | |
| | #7 (permalink) |
| | Re: SQLMetal - Problem generating VB from DBML Hi Adrian, Thanks for your reply and inform us of the result. Sincerely, Steven Cheng Microsoft MSDN Online Support Lead -------------------- Quote: >Reply-To: "Adrian" <apparker@xxxxxx> >From: "Adrian" <apparker@xxxxxx> >Subject: Re: SQLMetal - Problem generating VB from DBML >Date: Fri, 28 Mar 2008 08:17:03 -0000 > >Hi Steven, > >I've now written a routine to correct the column sequence in the xml to >match the actual primary key. The code generates fine now. > >"Steven Cheng [MSFT]" <stcheng@xxxxxx> wrote in message >news QdzKgwjIHA.5204@xxxxxx>| Hi Adrian, >| >| I've performed some further research on this issue and consult some other >| experts on this. Some engineers from dev team told me that this is an by >| designed behavior of the LINQ DBML generation. currently, it will require >| you to keep the column orders(in your "ThisKey" and "OtherKey" ) the same >| as the column sequence in the table schema. Changing the order will make >| the generated code become mismatch on the column/fields's assignment. >| >| Sincerely, >| >| Steven Cheng >| >| Microsoft MSDN Online Support Lead >| >| >| Delighting our customers is our #1 priority. We welcome your comments and >| suggestions about how we can improve the support we provide to you. Quote: >| feel free to let my manager know what you think of the level of service >| provided. You can send feedback directly to my manager at: >| msdnmg@xxxxxx. >| >| This posting is provided "AS IS" with no warranties, and confers no >rights. >| >| >| -------------------- >| >From: stcheng@xxxxxx ("Steven Cheng") >| >Organization: Microsoft >| >Date: Mon, 24 Mar 2008 09:34:34 GMT >| >Subject: Re: SQLMetal - Problem generating VB from DBML >| >| > >| >Hi Adrian, >| > >| >For the DBML document you mentioned, I've also tested it. Yes, if we Quote: >| >the three primary columns and their order always as 1, 2, 3 in all >| places, >| >it will generate code as expected. However, if we change the order as >| >below(in your customized DBML): >| > >| >ThisKey="keycol3,keycol1,keycol2" OtherKey="fkeycol3,fkeycol1,fkeycol2" >| > >| >the code it generate does seem different between the columns order in >| >DBML. I'll do some further research to see whether there is anything >which >| >can control this. >| > >| >Sincerely, >| > >| >Steven Cheng >| > >| >Microsoft MSDN Online Support Lead >| > >| > >| >Delighting our customers is our #1 priority. We welcome your comments Quote: >| >suggestions about how we can improve the support we provide to you. >Please >| >feel free to let my manager know what you think of the level of service >| >provided. You can send feedback directly to my manager at: >| >msdnmg@xxxxxx >| > >| >This posting is provided "AS IS" with no warranties, and confers no >rights. >| > >| > >| > >| >-------------------- >| >>Reply-To: "Adrian" <apparker@xxxxxx> >| >>From: "Adrian" <apparker@xxxxxx> >| >>References: <uPcn4ddhIHA.748@xxxxxx> >| ><SBISRf$hIHA.4672@xxxxxx> >| >>Subject: Re: SQLMetal - Problem generating VB from DBML >| >>Date: Mon, 17 Mar 2008 10:50:34 -0000 >| >>Steven, >| >> >| >>The dbml file is one we 'adjust' from the normal one generated by >| >SQLMetal.. >| >>we have to 'fix' some of the Member entries as they're badly named by >| >>sqlmetal. >| >> >| >>Followd your link and tried to validate, but when I go to the Quote: >| >>window in VS, it doesn't give me a 'Schema' property to select.. it Quote: >| >>gives.. >| >> >| >>Access: Public >| >>Base Class: System.Data.Linq.DataContext >| >>+Connection >| >>Context Namespace: MyConNS >| >>Entity Namespace: MyEntNs >| >>Inheritance Modifier: (None) >| >>Name: DBdc >| >>Serialization Mode: None >| >> >| >> >| >>Anyway, thinking about it, it does generate the VB, it just gets some >| >>columns switched around. As I said, it seems like it's not using the >| >order >| >>of the ThisKey and OtherKey when creating the code, but is taking the >| >order >| >>of the columns in the <column> elements. >| >> >| >> >| >> >| >> >| >>""Steven Cheng"" <stcheng@xxxxxx> wrote in message >| >>news:SBISRf$hIHA.4672@xxxxxx >| >>| Hi Adrian, >| >>| >| >>| As for the DBML file you provided, how did you generate it? >| >>| >| >>| For general validation, you can use the DBML schemas to validate the >| DBML >| >>| to see whether there is any XML schema specific errors. Here is the >MSDN >| >>| reference about this: >| >>| >| >>| #How to: Validate DBML and External Mapping Files (LINQ to SQL) >| >>| http://msdn2.microsoft.com/en-us/library/bb882675.aspx >| >>| >| >>| if there doesn't exist such error. I think there may have some Quote: >| >>| database related things cause potential problems. >| >>| >| >>| Sincerely, >| >>| >| >>| Steven Cheng >| >>| >| >>| Microsoft MSDN Online Support Lead >| >>| >| >>| >| >>| Delighting our customers is our #1 priority. We welcome your comments >| and >| >>| suggestions about how we can improve the support we provide to you. >| >Please >| >>| feel free to let my manager know what you think of the level of >service >| >>| provided. You can send feedback directly to my manager at: >| >>| msdnmg@xxxxxx. >| >>| >| >>| ================================================== >| >>| This posting is provided "AS IS" with no warranties, and confers no >| >>rights. >| >>| >| >>| -------------------- >| >>| >Reply-To: "Adrian" <apparker@xxxxxx> >| >>| >From: "Adrian" <apparker@xxxxxx> >| >>| >Subject: SQLM >| >>| >| >>| >I have a test DBML file:- >| >>| ><?xml version="1.0" encoding="utf-8"?> >| >>| ><Database Name="myDB" EntityNamespace="MyEntNS" >| >>ContextNamespace="MyConNs" >| >>| Class="DBdc" Quote: >| >>| > <Table Name="dbo.PARENTTABLE" Member="PARENTTABLE"> >| >>| > <Type Name="PARENTTABLE"> >| >>| > <Column Name="keycol1" Member="keycol1" Type="System.Decimal" >| >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" Quote: >/> >| >>| > <Column Name="keycol2" Member="keycol2" Type="System.Decimal" >| >>| DbType="Decimal(10,0) NOT NULL" IsPrimaryKey="true" Quote: >/> >| >>| > <Column Name="keycol3" Member="keycol3" Type="System.String" >| >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" Quote: >| >>| > <Association Name="fk_1064" Member="fkCHILDTABLE" >| >>| ThisKey="keycol3,keycol1,keycol2" >OtherKey="fkeycol3,fkeycol1,fkeycol2" >| >>| Type="CHILDTABLE" DeleteRule="NO ACTION" /> >| >>| > </Type> >| >>| > </Table> >| >>| > <Table Name="dbo.CHILDTABLE" Member="CHILDTABLE"> >| >>| > <Type Name="CHILDTABLE"> >| >>| > <Column Name="main_id" Member="publish_id" Quote: >| >>| DbType="VarChar(10) NOT NULL" IsPrimaryKey="true" CanBeNull="false" Quote: >| >>| > <Column Name="fkeycol1" Member="fkeycol1" Quote: >| >>| DbType="Decimal(10,0)" CanBeNull="true" /> >| >>| > <Column Name="fkeycol2" Member="fkeycol2" Quote: >| >>| DbType="Decimal(10,0)" CanBeNull="true" /> >| >>| > <Column Name="fkeycol3" Member="fkeycol3" Type="System.String" >| >>| DbType="VarChar(10)" CanBeNull="true" /> >| >>| > <Association Name="fk_1064" Member="pkPARENTTABLE" >| >>| ThisKey="fkeycol3,fkeycol1,fkeycol2" >OtherKey="keycol3,keycol1,keycol2" >| >>| Type="PARENTTABLE" IsForeignKey="true" /> >| >>| > </Type> >| >>| > </Table> >| >>| ></Database> >| >>| >Note that the order of the columns on the PARENTTABLE are listed >| >>correctly >| >>| as keycol1, keycol2, keycol3, but the promary key on the table is >| >actually >| >>| keycol3, keycol1, keycol2. The association elements do use the >correct >| >>| primary key sequences. However, when I generate the VB for this >DBML, >| >it >| >>| gets it wrong.. see the text below highlighted in red. >| >>| > <Association(Name:="fk_1064", Storage:="_pkPARENTTABLE", >| >>| ThisKey:="fkeycol3,fkeycol1,fkeycol2", IsForeignKey:=true)> _ >| >>| > Public Property pkPARENTTABLE() As PARENTTABLE >| >>| > Get >| >>| > Return Me._pkPARENTTABLE.Entity >| >>| > End Get >| >>| > Set >| >>| > Dim previousValue As PARENTTABLE = Me._pkPARENTTABLE.Entity >| >>| > If ((Object.Equals(previousValue, value) = false) _ >| >>| > OrElse (Me._pkPARENTTABLE.HasLoadedOrAssignedValue = false)) >| Then >| >>| > Me.SendPropertyChanging >| >>| > If ((previousValue Is Nothing) _ >| >>| > = false) Then >| >>| > Me._pkPARENTTABLE.Entity = Nothing >| >>| > previousValue.fkCHILDTABLE.Remove(Me) >| >>| > End If >| >>| > Me._pkPARENTTABLE.Entity = value >| >>| > If ((value Is Nothing) _ >| >>| > = false) Then >| >>| > value.fkCHILDTABLE.Add(Me) >| >>| > Me._fkeycol3 = value.keycol1 >| >>| > Me._fkeycol1 = value.keycol2 >| >>| > Me._fkeycol2 = value.keycol3 >| >>| > Else >| >>| > Me._fkeycol3 = CType(Nothing, String) >| >>| > Me._fkeycol1 = CType(Nothing, Nullable(Of Decimal)) >| >>| > Me._fkeycol2 = CType(Nothing, Nullable(Of Decimal)) >| >>| > End If >| >>| > Me.SendPropertyChanged("pkPARENTTABLE") >| >>| > End If >| >>| > End Set >| >>| > End Property >| >>| >Is there something wrong with the DBML or is it a bug in SQLMetal ? >| >>| >(this is using the RTM (1.00.21022) version of SQLMetal) >| >>| >-- >| >>| >Adrian >| >>| > >| >>| >| >> >| >> >| >> >| > >| > >| > > > |
| new Theme generating | Virtual PC | |||
| Problem with generating a certificate | Network & Sharing | |||
| Thumbnail problem. Computer not generating them or something. | Vista music pictures video | |||
| PROBLEM WITH VS 2008 WINFORMS LINQ TREATED FOR GENERATING A INSTALLER | .NET General | |||
