| Guest | ConfigurationManager with file attribute problem My app.config file has the setting <MySection file="My.config"> When I use "System.Configuration.ConfigurationManager.GetSection(SectionName)" it correctly reads from the My.config file for MySection. However, when I use "System.Configuration.ConfigurationManager.OpenExeConfiguration().GetSection(SectionName)it does not read from the file. Is this a bug? How do I figure out where it's loading the section from, so I can at least open the config file by filename? |
| Editing a .exe.config file with the class "ConfigurationManager" | .NET General | |||
| Read-only File and Folder Attribute | Tutorials | |||
| explorer file attribute | Vista General | |||
| File with mysterious attribute can't be seen | Vista file management | |||
| What is file attribute N? | Vista General | |||
