| | PROBLEM WITH VS 2008 WINFORMS LINQ TREATED FOR GENERATING A INSTALLER I have an application that this throws with VS 2008 and LINQ everything works well, the problem is when I try to create an installer for this project. Adding a project to install add the main results of the project as it is commonly I generate the installer and it gives me an error in the generation but I said that wrong or anything that file was also concerned with adding all the results osea the source for the project xml and nothing gives me the same mistake. Hize generating a quick test with an installer vs. 2008 2008 when working with WINFORMS LINQ I hope I can help, Thanks |
| | Re: PROBLEM WITH VS 2008 WINFORMS LINQ TREATED FOR GENERATING A INSTALLER If you feel a need to post the same question to multiple groups, CROSS-POST, don't MULTI-POST. http://en.wikipedia.org/wiki/Cross-post RobinS. "VictorLeo" <victor_leo18@xxxxxx> wrote in message news:4220ad34-1f88-48cc-9bcc-d2205ab53e8c@xxxxxx Quote: >I have an application that this throws with VS 2008 and LINQ > everything works well, the problem is when I try to create an > installer for this project. > > Adding a project to install add the main results of the project as it > is commonly I generate the installer and it gives me an error in the > generation but I said that wrong or anything that file was also > concerned with adding all the results osea the source for the project > xml and nothing gives me the same mistake. > > Hize generating a quick test with an installer vs. 2008 2008 when > working with WINFORMS LINQ > > I hope I can help, Thanks |
| Problem with generating a certificate | Network & Sharing | |||
| Thumbnail problem. Computer not generating them or something. | Vista music pictures video | |||
| SQLMetal - Problem generating VB from DBML | .NET General | |||
| cd drive treated as R/W | Vista General | |||
