| | In any project, Can't we refer classes directly, (without addingphysically in the project)? Hi ! I am new to .net. Presently, Working in vb.net 1.1 i have Created one class project and one client project (2 separate solutions) In the client project , if I try to ' add reference' for class, nothing is shown under project bar. I have to cumpulsorily add class project into my client project (add existing class), then only it shows class name under reference- project bar. does it mean every time I have to add required no. of classes physically, in any project? Then again give the reference of each? Can't it directly refered without adding physically? In Class project, I have used 'build Solution' from menu bar. In Client project, I tried 'browse' option,too. But it does not show class name untill physically added. ( file type: component files) What is the way to generate DLL? Thanks, Regards, Rachana |
| | RE: In any project, Can't we refer classes directly, (without adding p You need to set a reference to the assembly containing the class. This will allow you to set up a namespace in your client project and then you can reference classes in the referenced assembly. Eagle "Rachana" wrote: Quote: > Hi ! > I am new to .net. Presently, Working in vb.net 1.1 > i have Created one class project and one client project (2 separate > solutions) > In the client project , if I try to ' add reference' for class, > nothing is shown under project bar. > I have to cumpulsorily add class project into my client project (add > existing class), then only it shows class name under reference- > project > bar. > does it mean every time I have to add required no. of classes > physically, in any project? Then again give the reference of each? > Can't it directly refered without adding physically? > > In Class project, I have used 'build Solution' from menu bar. > In Client project, I tried 'browse' option,too. > But it does not show class name untill physically added. ( file type: > component files) > > What is the way to generate DLL? > > Thanks, > Regards, > Rachana > |
| Hp m9040n project | General Discussion | |||
| Cannot create new project | .NET General | |||
| Project playlist | Chillout Room | |||
| web.config vs. My Project | .NET General | |||
| Microsoft Advances Its Project Management Technology and the Project Management Profession | Vista News | |||
