| | Registrykey reading problems Hi, I'm trying to read a registry key: I've tried: RegistryKey rkey1 = rkey.OpenSubKey( "SYSTEM\\CurrentControlSet\\Services\\Rendering Service"); then RegistryKey rkey1 = rkey.OpenSubKey( "SYSTEM\\CurrentControlSet\\Services\\Rendering Service\\"); due to problems I've tried RenderingQ = rkey1.GetValue("RenderingQOnDemandQ"); which gave an error when compiling of Error 6 Cannot implicitly convert type 'object' to 'string'. An explicit conversion exists (are you missing a cast?) which seems weird, from the documentation I thought GetValue returned a string? so I tried: RenderingQ = rkey1.GetValue("RenderingQOnDemandQ").ToString(); that compiles. When I run it however I get a null value exception (the same situation exists for all the various keys I'm working with) if I do a registry dump of the key I'm working with I get: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Rendering Service] and "RenderingQOnDemandQ"="C:\\RenditionServerQ\\QueueManagerQ\\OnDemandQ" So I suppose there is something simple that i don't know about working with the registry in .Net that someone can help me with? Is it a casting exception? How should I cast? |
| | Re: Registrykey reading problems On Mar 31, 10:42 am, pantagruel <rasmussen.br...@xxxxxx> wrote: Quote: > Hi, > > I'm trying to read a registry key: > > I've tried: > > RegistryKey rkey1 = rkey.OpenSubKey( > "SYSTEM\\CurrentControlSet\\Services\\Rendering Service"); > > then > RegistryKey rkey1 = rkey.OpenSubKey( > "SYSTEM\\CurrentControlSet\\Services\\Rendering Service\\"); > due to problems > > I've tried > > RenderingQ = rkey1.GetValue("RenderingQOnDemandQ"); > > which gave an error when compiling of > Error 6 Cannot implicitly convert type 'object' to 'string'. An > explicit conversion exists (are you missing a cast?) > > which seems weird, from the documentation I thought GetValue returned > a string? > so I tried: > > RenderingQ = rkey1.GetValue("RenderingQOnDemandQ").ToString(); > > that compiles. > > When I run it however I get a null value exception (the same situation > exists for all the various keys I'm working with) > > if I do a registry dump of the key I'm working with I get: > > [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Rendering > Service] > > and > "RenderingQOnDemandQ"="C:\\RenditionServerQ\\QueueManagerQ\\OnDemandQ" > > So I suppose there is something simple that i don't know about working > with the registry in .Net that someone can help me with? > > Is it a casting exception? > How should I cast? Registry.LocalMachine; |
| | Re: Registrykey reading problems It definitely returns an object - after all, not all attributes are strings. You might want to double-check the key name; equally, using string literals (i.e. @"foo") can make it easier to avoid escaping issues. Using a different key (that exists on my machine) the following works fine: string value = Convert.ToString( Registry.GetValue(@"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RemoteAccess", @"DisplayName", null)); Marc |
| | RE: Registrykey reading problems Be aware that registry virtualization on Vista or 64bit OS's will mess up your mind in this scenario. If you are on 32 bit XP however, I don't see why this wouldn't work, given the key is specified correctly. "pantagruel" wrote: Quote: > Hi, > > I'm trying to read a registry key: > > I've tried: > > RegistryKey rkey1 = rkey.OpenSubKey( > "SYSTEM\\CurrentControlSet\\Services\\Rendering Service"); > > then > RegistryKey rkey1 = rkey.OpenSubKey( > "SYSTEM\\CurrentControlSet\\Services\\Rendering Service\\"); > due to problems > > I've tried > > RenderingQ = rkey1.GetValue("RenderingQOnDemandQ"); > > which gave an error when compiling of > Error 6 Cannot implicitly convert type 'object' to 'string'. An > explicit conversion exists (are you missing a cast?) > > which seems weird, from the documentation I thought GetValue returned > a string? > so I tried: > > RenderingQ = rkey1.GetValue("RenderingQOnDemandQ").ToString(); > > that compiles. > > When I run it however I get a null value exception (the same situation > exists for all the various keys I'm working with) > > if I do a registry dump of the key I'm working with I get: > > [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Rendering > Service] > > and > "RenderingQOnDemandQ"="C:\\RenditionServerQ\\QueueManagerQ\\OnDemandQ" > > So I suppose there is something simple that i don't know about working > with the registry in .Net that someone can help me with? > > Is it a casting exception? > How should I cast? > > > > > |
| start up problems - i've been reading threads all night !! | .NET General | |||
| Problems reading Vista 64-Bit OS installation DVD after clone copy | Vista installation & setup | |||
| Sony MemoryStick card reading problems in x64 - NOT in x86! | General Discussion | |||
| Re: Some Problems, mainly with Reading CDs? | Vista General | |||
| Problems Reading Disks in RC1 | Vista hardware & devices | |||
