Vista - LINQ - Speed penalty/anonymous types
Old 03-31-2008   #1 (permalink)
Peter Larsen [CPH]
I'm wondering if the use of anonymous types slow down the app at runtime or
not.
See the following sample:
var obj1 = from item in list select new { item.ClassID, AnyName
= item.ClassID };
foreach (var item in obj1)
string s1 = item.ClassID;
string s2 = item.AnyName;
I know lot of the work is done at compile time, but i still wondering if it
slows down the application to use anonymous types:
Is it slower to use ?
BR
Peter
Old 03-31-2008   #2 (permalink)
Jon Skeet [C# MVP]
Re: LINQ - Speed penalty/anonymous types
Peter Larsen [CPH] <PeterLarsen@xxxxxx> wrote:
> not.
> = item.ClassID };
No. It's anonymous at compile time, but it's a perfectly ordinary type
as far as the CLR is concerned. All you're doing in the above is
calling a constructor and then retrieving properties.
Of course, in the above case you could just go directly to the members
of the list, but I'm assuming in real life that you actually have a
reason to use the anonymous type in the first place.
Jon Skeet - <skeet@xxxxxx>
http://www.pobox.com/~skeet Blog: http://www.msmvps.com/jon.skeet
World class .NET training in the UK: http://iterativetraining.co.uk
Old 03-31-2008   #3 (permalink)
Peter Larsen [CPH]
Thanks for your comment.
It's just sample code - i'm not using it anywhere.
/Peter
Old 03-31-2008   #4 (permalink)
Marc Gravell
In this case, with a list - it would be *slightly* more efficient to just
access each item in the list, since it avoids creating a short-lived object
per row - i.e.
foreach(var originalItem in list) {
// do something with originalItem.ClassID etc
However, if "list" is actually an IQueryable (or similar) source such as an
LINQ-to-SQL DataContext, then your original (projection-based) code would be
more efficient: in this case, the provider can usually do something clever -
i.e. with SQL it can build a SELECT statement that only includes the two
columns, and doesn't worry about change-tracking etc.
Marc
Old 04-01-2008   #5 (permalink)
Peter Larsen [CPH]
Thanks for your comment Marc.
Tweaker anonymous? General Discussion
Performance penalty between dynamic- and fixed-size virtual hard disks? Virtual PC
Aero Performance Penalty Enormous Vista performance & maintenance
Performance penalty with DEP? (Data Execution Prevention) Vista General
