| | vs2008 express help problem I installed vs2008 express without problem. I have registered the product. I made a project and it runs ok. I did F1 on the word "Class" and the proper help page showed up. Help browsing worked ok for various items of information. (Hence, help is installed, and Add/Remove programs confirms the installation of "MSDN Library for Microsoft Visual Studio 2008 Express Editions"). But, when I tried to get to the .NET Framework Class Library Reference, I get a general error page that says "Information Not Found". What do I need to do to see the Class Library Reference? Some text from the error page is included below: Information Not Found The information that you are trying to access could not be found. Various events could have caused this error. Broken links No topic in Local Help No F1 Help topic available Online Help is not available Help has not been installed Online Help cannot be accessed because the proxy server cannot authenticate the user To report this error, visit the MSDN Product Feedback Center. A cross-reference link in the body of a topic is broken. |
| | RE: vs2008 express help problem I did a search in MSDN for this errror, and someone named Kathleen wanted answers to the questions below. So FYI... 1. Whiich profile did you selected when you installed Visual Studio? (i.e. did you indicate that Visual Basic is the environment you use most?) - Yes, VB and only VB. 2. In your Help options, (open Help, then go to Tools|Options), which setting do you have selected under "When loading Help content"? - I've tried both online first then local, and local first then online, current setting is online first then local. 3. Did you install the MSDN Library locally on your computer? - add/remove programs confirms that "MSDN Library for Microsoft Visual Studio 2008 Express Editions" is installed. I did not specifically install it, but it was installed as part of installing vs 2008 express. 4. Does the error within Document Explorer occur whenever you perform a search? If it only occurs on certain searches, please give me an example of the search string you used? - the page ".NET Framework Reference Information" has links, eg to class library reference, and the links give the error. |
| C# express in VS2008 SP1 won't let you target 2.0 | .NET General | |||
| Problem running VS2008 Compiled EXE | .NET General | |||
| Upgrading from VS2008 standard to VS2008 Pro? | .NET General | |||
| upgrade from VS2008 standard to VS2008 pro- options? | .NET General | |||
