Vista - Non Virtual method using CodeMemberMethod -- CodeDOM
Old 04-01-2008   #1 (permalink)
Abhi
I am using CodeDOM namespace to dynamically generate code in C#. But when I
am creating method using “CodeMemberMethod” then its creating a virtual
method even though I am not specifying anything to create a virtual method. I
am using following code to add method:
CodeMemberMethod testMethod = new CodeMemberMethod();
testMethod.Name = "testMethod";
testMethod.Attributes = MemberAttributes.Public;
testMethod.Statements.Add(new CodeSnippetStatement("//TODO: Code goes
here....."));
testClassType.Members.Add(testMethod);
Question: How to create method without Virtual keyword?
Unable to install Virtual Guest Services on virtual machine Virtual Server
Vista Home Premium .. Can't install Virtual Server.. so how do Iautomatically start a Virtual PC without a login? Virtual PC
How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM Virtual Server
Method invocation failed because [System.String] doesn't contain a method PowerShell
Designer Media Ltd
