| | Newbie: Article or help topic on deployment with tables Hi, VS2005 running with SQL Server Express. My app needs a simple table, if I include the mdf with the deployment, then the database will be overwritten with updates (losing the data). So does anyone know of a good article/tutorial describing how to deploy a simple table via scripts particularly in regards to what happens when you bring out a new release? Thanks. |
| | Re: Newbie: Article or help topic on deployment with tables What method are you using to deploy your application? Are you using ClickOnce Deployment, or a Setup & Deployment package? RobinS. "Paul Hemans" <darwin@xxxxxx> wrote in message news:OSdrPsvlIHA.5260@xxxxxx Quote: > Hi, > VS2005 running with SQL Server Express. My app needs a simple table, if I > include the mdf with the deployment, then the database will be overwritten > with updates (losing the data). So does anyone know of a good > article/tutorial describing how to deploy a simple table via scripts > particularly in regards to what happens when you bring out a new release? > > Thanks. > |
| | Re: Newbie: Article or help topic on deployment with tables I am using a Setup & Deployment package "RobinS" <robins@xxxxxx> wrote in message news:rtidndT8R5eW9mTanZ2dnUVZ_jqdnZ2d@xxxxxx Quote: > What method are you using to deploy your application? Are you using > ClickOnce Deployment, or a Setup & Deployment package? > > RobinS. > > "Paul Hemans" <darwin@xxxxxx> wrote in message > news:OSdrPsvlIHA.5260@xxxxxx Quote: >> Hi, >> VS2005 running with SQL Server Express. My app needs a simple table, if I >> include the mdf with the deployment, then the database will be >> overwritten with updates (losing the data). So does anyone know of a good >> article/tutorial describing how to deploy a simple table via scripts >> particularly in regards to what happens when you bring out a new release? >> >> Thanks. >> |
| | Re: Newbie: Article or help topic on deployment with tables Dang. I can't help you there. You might try posting to the MSDN ClickOnce/Setup & Deployment forum. There's a guy there named Phil Wilson who seemed to be an expert on S&D packages. Good luck. RobinS. GoldMail.com "Paul Hemans" <darwin@xxxxxx> wrote in message news:OSk42AQmIHA.748@xxxxxx Quote: >I am using a Setup & Deployment package > "RobinS" <robins@xxxxxx> wrote in message > news:rtidndT8R5eW9mTanZ2dnUVZ_jqdnZ2d@xxxxxx Quote: >> What method are you using to deploy your application? Are you using >> ClickOnce Deployment, or a Setup & Deployment package? >> >> RobinS. >> >> "Paul Hemans" <darwin@xxxxxx> wrote in message >> news:OSdrPsvlIHA.5260@xxxxxx Quote: >>> Hi, >>> VS2005 running with SQL Server Express. My app needs a simple table, if >>> I include the mdf with the deployment, then the database will be >>> overwritten with updates (losing the data). So does anyone know of a >>> good article/tutorial describing how to deploy a simple table via >>> scripts particularly in regards to what happens when you bring out a new >>> release? >>> >>> Thanks. >>> > |
| Help with Deployment Workbench and Deployment Services | Vista installation & setup | |||
| Route Tables ?? | Vista General | |||
| Multiple tables | .NET General | |||
| Micrsoft Deployment and Vista image deployment.... | Vista installation & setup | |||
| tables in wlm | Live Mail | |||
