Vista - Extension Method Question for ServicedComponent
Old 04-05-2008   #1 (permalink)
coconet
..NET 3.5
If I understand correctly, extension methods must be in a public
static class. I have some code that executes in a COM+ application for
object pooling purposes. I am trying to update it by using LINQ and an
extension method. I think my code that inherits from ServicedComponent
cannot have any public static code, all methods must be instance
methods.
How can I make this stuff all work together?
Thanks.
Old 04-06-2008   #2 (permalink)
Anthony Jones
Re: Extension Method Question for ServicedComponent
"coconet" <coconet@xxxxxx> wrote in message
news:g2dgv3l28lev12mj6g0rmjvj3kflltc7ls@xxxxxx
Quote:
> .NET 3.5
> methods.
If I've understood your question correctly I don't think you can.
You will need to create additional interfaces to expose your new methods,
extension methods are not callable via COM since COM requires an interface.
Anthony Jones - MVP ASP/ASP.NET
Question about Copy() method in Excel PowerShell
method not many Vista mail
Method invocation failed because [System.String] doesn't contain a method PowerShell
Question about passing array to a .Net method PowerShell
