| | Help with Logging Sinks Hi! I'm using the Microsoft Enterprise Library 3.1 for logging with the Enterprise Library Configuration tool. I've seen a couple of screenshots for the configuration tool, but I can't seem to get the Sinks node in the tool that I'm using. Am I stuck with using the Windows Events log or did Microsoft decide to let developers/ administrators use their XML editing skills and sense of direction to figure out how to modify the config file manually? -NiTiN |
| Logging on | Vista mail | |||
| logging in? | Vista mail | |||
Logging out | Chillout Room | |||
| Logging | Vista mail | |||
| Logging In | Vista mail | |||
