Vista - Help Favorites
Old 04-06-2008   #1 (permalink)
SurturZ
Help Favorites
Hi All,
One disappointment in VS2008 is that Microsoft has not improved the
'favorites' section of the help browser.
Specifically, an ability to organise favorites in folders, and to sort them
by name would be nice.
I'm hoping these features are already there and someone here can enlighten
me on how to use them, but if they aren't, is there a back door way to access
the help favorites and at least sort them via windows explorer or somesuch?
David Streeter
Synchrotech Software
Sydney Australia
Old 04-06-2008   #2 (permalink)
SurturZ
RE: Help Favorites
I worked it out!
Imports System.Xml
Module modMain
Sub Main()
'sorts help favorites in VS Help
'C:\Documents and Settings\dstreeter\Application
Data\Microsoft\VisualStudio\9.0\VS Help Data
Dim strAppDataBasePath As String =
My.Computer.FileSystem.SpecialDirectories.CurrentUserApplicationData
strAppDataBasePath = Left(strAppDataBasePath,
InStr(strAppDataBasePath, "Application Data\") + 16)
Dim strFilename As String = strAppDataBasePath &
"\Microsoft\VisualStudio\9.0\VS Help Data\Favorites.xml"
Dim strOutputFilename As String = strAppDataBasePath &
"\Microsoft\VisualStudio\9.0\VS Help Data\FavoritesNew.xml"
Dim strXML As String = My.Computer.FileSystem.ReadAllText(strFilename)
Dim xdc As New XmlDocument
xdc.LoadXml(strXML)
Dim xndTopics As XmlNode = xdc.ChildNodes(1).ChildNodes(0)
If xndTopics.Name <> "FavoriteTopics" Then
Console.WriteLine("Bad file: " & strFilename)
GoTo EndProg
End If
'bubble sort
For outer As Integer = xndTopics.ChildNodes.Count - 2 To 0 Step -1
Dim intSwaps As Integer = 0
For inner As Integer = 0 To outer
If
xndTopics.ChildNodes(inner).ChildNodes(0).ChildNodes(0).Value >
xndTopics.ChildNodes(inner + 1).ChildNodes(0).ChildNodes(0).Value Then
Dim xnd As XmlNode =
xndTopics.ChildNodes(inner).CloneNode(True)
xndTopics.ReplaceChild(xndTopics.ChildNodes(inner +
1).CloneNode(True), xndTopics.ChildNodes(inner))
xndTopics.ReplaceChild(xnd, xndTopics.ChildNodes(inner +
1))
intSwaps += 1
End If
Next inner
If intSwaps = 0 Then Exit For
Next outer
On Error Resume Next
Kill(strOutputFilename)
On Error GoTo 0
xdc.Save(strOutputFilename)
Console.WriteLine("Sorted file saved as " & strOutputFilename)
EndProg:
Console.ReadKey()
End Sub
End Module
David Streeter
Sydney Australia
"SurturZ" wrote:
Quote:
> Hi All,
> David Streeter
> Sydney Australia
Favorites Vista General
Cannot Add Favorites Network & Sharing
IE7 favorites fix Network & Sharing
Where are Favorites kept Vista General
Re: IE7: Cannot add to favorites Vista General
