Vista - Help, please. .NET on XP, versions and uninstalls.
Old 04-08-2008   #1 (permalink)
Al Dykes
My system is XPSP1, recently updated by Microsoft. It's an older
laptop and I'm running out of disk space.
I only installed my first ".NET' app recently, that I know of, and the
app setup pointed me to URLS to get it from. I dodn't pay attion to
sizes.
Now I find I have the following on my system. I know that version x+1
doesn't replace version x.
.NET 2.0 SP1 at 165MB
.NET 3.0 SP1 at 245MB
.NET 3.5 at 25MB
Questions:
- Do these file sizes indicate that I have a SDK kit where all I need
is a RTK and how much space would I save by just installing the RTK?
- How can I tell which apps on my machine are calling which versions
of .NET?
- I've uninstalled the only software I know of that requires .NET and
it still won't let me uninstall it. Googling for "uninstall .NET"
comes up with all sorts of pages for irrelevant cases such as beta
version, etc. It there a page about uninstall that applies to me?
- What are URLS for find each version as a RTK?
Thanks
Al Dykes
News is something someone wants to suppress, everything else is advertising.
- Lord Northcliffe, publisher of the Daily Mail
Old 04-08-2008   #2 (permalink)
Norman Yuan
Re: Help, please. .NET on XP, versions and uninstalls.
Firstly, you have only one version (and the latest version) of .NET
framework installed. That is .NET3.5, which is something built on top of
..NET3.0SP1, which in turn is something built on top of .NET2.0.
Secendly, the size showed in "Add/Remove programs" window may not be the
actual package size. In the regards of .NET framework, the size showed there
varies depending on OS (XP, Server, VISTA...).
To see if it is RTK plus full SDK (which you do not need to save disk
space), you can simply see if you have "Microsoft .NET Framework SDK v2.0"
listed in "Start->Programs". If no, you likely have RTK, rather than SDK.
"Al Dykes" <adykes@xxxxxx> wrote in message
news:ftg6aj$j9t$1@xxxxxx
> sizes.
> .NET 3.5 at 25MB
> Questions:
> of .NET?
> Thanks
> Al Dykes
> advertising.
Old 04-08-2008   #3 (permalink)
Al Dykes
In article <ORkhFZamIHA.4208@xxxxxx>,
Thanks, I'm happy to hear that 3.5 replaces 2.0, and 3.0. Others have
told me that I need all versions. I can believe that Control Panel
doesn't report disk space accurately. It appears that I don't have
the SDK.
I believe that only two minor apps need .NET and I've uninstalled
them.
Is there any way to tell which apps on my machine need .NET and which
versions?
Is there a cookbook way to uninstall .NET? When I try to uninstall, I
get a "can't uninstall msg and a search of the MS KB shows
complications but for versions I don't have.
Al Dykes
Old 04-08-2008   #4 (permalink)
Norman Yuan
news:ftgemr$k8p$1@xxxxxx
>>there
> the SDK.
No, What I actually meant is that although you see 3 version of .NET
(2.0SP1, 3.0SP1 and 3.5), you actually is having full 3.5. You CANNOT not
remove either 2.0SP1 or 3.0SP1 to leave 3.5 still working. All the three
must be there. If you use VISTA, you will not see either .NET2.0 or .NET3.0
in the "Add/remove program" window, because they are part of OS.
> them.
> versions?
> Al Dykes
> advertising.
Old 04-08-2008   #5 (permalink)
Al Dykes
In article <epHJySbmIHA.4196@xxxxxx>,
>>>there
>> the SDK.
OK. How do I remove them all?
Al Dykes
Old 04-09-2008   #6 (permalink)
David Griffiths
Do you need SP2 for Win XP installed to install the .Net 2.0 & 3.x versions.
The OP reports his system as a WinXP SP1 system
Right click "My Computer" and choose "Properties" and tell us what that
reports.
DaveG
> sizes.
> .NET 3.5 at 25MB
> Questions:
> of .NET?
> Thanks
> Al Dykes
> advertising.
Old 04-09-2008   #7 (permalink)
Al Dykes
In article <qeGdnRVLNsJoW2HaRVnzvQA@xxxxxx>,
>reports.
It's SP2, Thanks for catching that.
I was able to uninstall .NET 3.5 (the latest) after uninstalling the
two apps that I know use .NET. I'm going to live with the system for
a few days to see if anything broke. Then I'll try to ininstall 2.0
Quote:
>DaveG
>> sizes.
>> .NET 3.5 at 25MB
>> Questions:
>> of .NET?
>> Thanks
>> Al Dykes
>> advertising.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore. A Proud signature since 2001
Al Dykes
Folder Versions has Non Existent List in Previous Versions Tab Vista performance & maintenance
HP Photosmart C4200 All-in-One series , HP Laptop, UBS, Uninstalls Vista hardware & devices
Solution to post of 12/11/2007 File and printer sharing uninstalls after reboot Vista networking & sharing
File and print sharing uninstalls after rebooting Vista networking & sharing
OEM versions and Full Versions of Vista Vista installation & setup
