| | WebClient Freezes for Ten Seconds on First Connect I've build a client-server application in which the client communicates with the server by making calls to WebClient.UploadValuesAsync(). In a given client session, hundreds of calls will be made and generally speaking I'm pleased with the performance. It only takes a few milliseconds from the time UploadValuesAsync() is called to the time the server receives the request and begins processing it. The problem is that the FIRST call of the session takes around ten seconds to get from client to server. During this ten second period, the UploadValuesAsync() call blocks. Repeatedly running "netstat -n" at the command line indicates that the connection is not established during this period. Then, after ten sesconds, netstat shows the new connection, UploadValuesAsync() unblocks, and all is well. I can't for the life of me figure out what is causing this problem. The ten second hang time wouldn't really bother me in production mode, but it makes development a real pain, because each time I make a change to the code and want to test it, I have to deal with it. Any ideas? Jules |
| | Re: WebClient Freezes for Ten Seconds on First Connect Here's the solution for anyone who is interested: WebClient internally makes use of HttpWebRequest. HttpWebRequest exposes a property called Proxy which for some reason is, by default, set to a non-null value. This is despite the fact that I do NOT USE A PROXY, nor is Internet Explorer configured to use one. Anyway, the fact that this Proxy property is non-null is not problematic in most cases. My case is somewhat unusual, however, in that my development machine is connected via PPTP VPN to a remote network. Now, this shouldn't really matter since the server to which my app is connecting isn't on the other side of the VPN. The VPN isn't involved in the client-server transaction at ALL, but I noticed that when the VPN was disconnected, the ten second delay mentioned in my original post went away. Weird! It turns out that by manually setting the Proxy property to null on the WebClient (which in turn sets the Proxy property to null on the underlying HttpWebRequest), the problem is resolved. When the Proxy property is set to null, the delay goes away, regardless of whether or not the VPN is connected. Hopefully this will help someone else that runs into this bizarre bug. Jules |
| Vista freezes at green start up bar/freezes for a few seconds on desktop | General Discussion | |||
| Random freezes for about 20/30 seconds | General Discussion | |||
| Vista continuously freezes for a few seconds, please HELP!!! | Vista General | |||
| WMP 11 freezes for 2 seconds in the end of every song | Vista music pictures video | |||
| Vista freezes for 10-20 seconds | Vista performance & maintenance | |||
