Vista - Microsoft Jet Engine Replacement
Old 04-15-2008   #1 (permalink)
orcauser
The Microsoft Jet Engine is deprecated. It's probably not a good idea to use
the Microsoft Jet Engine in a new product development with .NET.
What is the replacement for the Jet Engine? Yes, there is the SQL Server /
SQL Server Express combination. But I'm looking for a database which is easy
to deploy and low administration expense. In a VB6 application you can use
the Microsoft Jet Engine. But what should you use in a .NET application?
Old 04-15-2008   #2 (permalink)
Chris Crowther MBCS
Re: Microsoft Jet Engine Replacement
SQL Server Compact Edition is about as low administration expense as you
can get within the product family:
http://www.microsoft.com/sql/edition...t/default.mspx
You could also look at the SQLite .NET port:
http://sqlite.phxsoftware.com/
Chris Crowther MBCS
C# Developer
RHD Research Ltd
Old 04-16-2008   #3 (permalink)
orcauser
Thanks for your response.
SQL Server Compact Edition looks nice in terms of low administration
expense. An embedded database is the right way. Sorry, I didn't mention that
we need multi-user access (up to 4 or 5 user). Unfortunately, SQL Server
Compact Edition supports only single user access.
Yes, SQLite .NET could meet the requirements.
Did someone gain experience with an embedded database like SQLite or VistaDb
(http://www.vistadb.net/)?
Microsoft offering replacement XP license for VISTA license? Vista performance & maintenance
Borland Database Engine Stopping Microsoft Outlook from Working Vista mail
speech engine Vista General
powershell engine PowerShell
Microsoft Researchers Inventing New Techniques to Improve Search Engine Accuracy and Relevance Vista News
