| | Convery WMI script into .NET (using VB.NET 2005) Problem: I need to backup and clear the security event log. I have this working via a vbsscript which I will post below. However while I can use this script manually it is not user friendly and my end users who have to perform the backup and clear chore weekly are the "where is the button" types. I have written a vb.net 2005 gui as a front end that can launch my script and run it ok but the problem is since it is a script running in a shell object I have no way to return status to my vb.net program saying it succeded or failed or even to know when the shell exits. So I decided to look into writing performing the steps via vb.net code. I can successfully create a WMI connection and (on the local machine) I can even list out all log files by code shown below. What I cannot do is execute the BackupEventLog method via WMI. I get access denied, which I have researched and I feel the reason is that the WMI connection does not have the privileges enabled for backup and security. If you look at the vbs script below you will see where it addes (Backup, security) into the moniker for the object and I believe allows the execution of the method. I did find out there that you are supposed to use the ".EnablePrivileges = True" option but I also found that .NET 1.1 messed that option up. Someone please help! CREATE CONNECTION CODE: ===================BEGIN Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click With myConnectionOptions .Impersonation = Management.ImpersonationLevel.Impersonate '* Use next line for XP .Authentication = System.Management.AuthenticationLevel.Packet .EnablePrivileges = True 'Cannot specify username/password for local connections '.Username = Me.txtUsername.Text '.Password = Me.txtPassword.Text End With '* "." is the string for a local connection Dim myServerName As String = Me.txtServer.Text myManagementScope = New System.Management.ManagementScope("\\" & myServerName & "\root\cimv2", myConnectionOptions) '* connect to WMI namespace myManagementScope.Connect() If myManagementScope.IsConnected = False Then rtbStatus.AppendText("Could not connect to WMI namespace on " & myServerName & ControlChars.Cr) Else rtbStatus.AppendText("Connected to WMI namespace on " & myServerName & ControlChars.Cr) End If End Sub ===================END LIST ALL LOG FILES CODE: ===================BEGIN Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click Dim logfileSearcher As System.Management.ManagementObjectSearcher Dim logfiles As System.Management.ManagementObjectCollection Dim logfile As System.Management.ManagementObject logfileSearcher = New System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, "Select * from win32_NTEventLogFile") '* execute query logfiles = logfileSearcher.Get() Try For Each logfile In logfiles rtbStatus.AppendText("Found logfile " & logfile.GetPropertyValue("FileName").ToString & " which is the " & logfile.GetPropertyValue("LogfileName").ToString & " event log" & ControlChars.Cr) 'INSERT BACKUP CODE HERE (SHOWN BELOW) Next Catch ex As Exception rtbStatus.AppendText("Error Encountered: " & ex.ToString & ControlChars.Cr) End Try End Sub ===================END FAILING BACKUP METHOD INVOCATION ===================BEGIN Dim inParams As Management.ManagementBaseObject = logfile.GetMethodParameters("BackupEventLog") inParams("ArchiveFileName") = "c:\testing.evt" Dim outParams As Management.ManagementBaseObject = logfile.InvokeMethod("BackupEventLog", inParams, Nothing) ===================END WORKING VBS SCRIPT ===================BEGIN 'Arguments fileName = WScript.Arguments.Item(0) logType = WScript.Arguments.Item(1) fullPathName = filename & ".evt" 'NOTE: for this to work on a normal user account they must have following rights 'Manage Auditing and Secuirty 'Generate Security Audits strComputer = "." Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate,(Backup,security)}!\\" & strComputer & "\root\cimv2") Set colLogFiles = objWMIService.ExecQuery ("SELECT * FROM Win32_NTEventLogFile WHERE LogFileName='" & logType & "'") For Each objLogfile in colLogFiles errBackupLog = objLogFile.BackupEventLog(fullPathName) If errBackupLog = 0 Then Wscript.Echo "The Security event log was backed up." objLogFile.ClearEventLog() End If If errBackupLog = 8 Then Wscript.Echo "Privilege missing!" End If If errBackupLog = 21 Then Wscript.Echo "Invalid Parameter in call" End If If errBackupLog = 183 Then Wscript.Echo "The archive file already exists." End If Next ===================END |
| | Re: Convery WMI script into .NET (using VB.NET 2005) Hi, You may be better of with microsoft.public.dotnet.framework.wmi in future for this type of thing. I can't help with the .NET side, as I don't use it, but a couple of things jump out at me from your post. 1. If the user is the "where the button" type, why are they allowed anywhere NEAR a security log. They'd need full admin rights for a start, and you've just lost your audit trail. 2. If the old version was working, and they just need a "button", why can't they just have shortcut to click on? 3. If it's for lots of users, why not just have a button on an intranet page where they click, and based on valid user authentication, this would start a new process in a new security context that would clear the log. 4. Why not just have a scheduled job to backup the log and then clear it? JohnBates wrote: Quote: > Problem: > I need to backup and clear the security event log. I have this working via > a vbsscript which I will post below. However while I can use this script > manually it is not user friendly and my end users who have to perform the > backup and clear chore weekly are the "where is the button" types. > > I have written a vb.net 2005 gui as a front end that can launch my script > and run it ok but the problem is since it is a script running in a shell > object I have no way to return status to my vb.net program saying it succeded > or failed or even to know when the shell exits. > > So I decided to look into writing performing the steps via vb.net code. I > can successfully create a WMI connection and (on the local machine) I can > even list out all log files by code shown below. What I cannot do is execute > the BackupEventLog method via WMI. I get access denied, which I have > researched and I feel the reason is that the WMI connection does not have the > privileges enabled for backup and security. If you look at the vbs script > below you will see where it addes (Backup, security) into the moniker for the > object and I believe allows the execution of the method. > > I did find out there that you are supposed to use the ".EnablePrivileges = > True" option but I also found that .NET 1.1 messed that option up. Someone > please help! > > CREATE CONNECTION CODE: > ===================BEGIN > Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As > System.EventArgs) Handles Button1.Click > > With myConnectionOptions > .Impersonation = Management.ImpersonationLevel.Impersonate > > '* Use next line for XP > .Authentication = System.Management.AuthenticationLevel.Packet > .EnablePrivileges = True > > 'Cannot specify username/password for local connections > '.Username = Me.txtUsername.Text > '.Password = Me.txtPassword.Text > End With > > '* "." is the string for a local connection > Dim myServerName As String = Me.txtServer.Text > > myManagementScope = New System.Management.ManagementScope("\\" & > myServerName & "\root\cimv2", myConnectionOptions) > > '* connect to WMI namespace > myManagementScope.Connect() > If myManagementScope.IsConnected = False Then > rtbStatus.AppendText("Could not connect to WMI namespace on " & > myServerName & ControlChars.Cr) > Else > rtbStatus.AppendText("Connected to WMI namespace on " & > myServerName & ControlChars.Cr) > End If > End Sub > ===================END > > LIST ALL LOG FILES CODE: > ===================BEGIN > Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As > System.EventArgs) Handles Button3.Click > Dim logfileSearcher As System.Management.ManagementObjectSearcher > Dim logfiles As System.Management.ManagementObjectCollection > Dim logfile As System.Management.ManagementObject > > logfileSearcher = New > System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, > "Select * from win32_NTEventLogFile") > > '* execute query > logfiles = logfileSearcher.Get() > > Try > > For Each logfile In logfiles > > rtbStatus.AppendText("Found logfile " & > logfile.GetPropertyValue("FileName").ToString & " which is the " & > logfile.GetPropertyValue("LogfileName").ToString & " event log" & > ControlChars.Cr) > > 'INSERT BACKUP CODE HERE (SHOWN BELOW) > > Next > > Catch ex As Exception > rtbStatus.AppendText("Error Encountered: " & ex.ToString & > ControlChars.Cr) > End Try > End Sub > ===================END > > > FAILING BACKUP METHOD INVOCATION > ===================BEGIN > Dim inParams As Management.ManagementBaseObject = > logfile.GetMethodParameters("BackupEventLog") > > inParams("ArchiveFileName") = "c:\testing.evt" > > Dim outParams As Management.ManagementBaseObject = > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > ===================END > > > WORKING VBS SCRIPT > ===================BEGIN > 'Arguments > fileName = WScript.Arguments.Item(0) > logType = WScript.Arguments.Item(1) > fullPathName = filename & ".evt" > > 'NOTE: for this to work on a normal user account they must have following > rights > 'Manage Auditing and Secuirty > 'Generate Security Audits > > strComputer = "." > Set objWMIService = GetObject("winmgmts:" & > "{impersonationLevel=impersonate,(Backup,security)}!\\" & strComputer & > "\root\cimv2") > Set colLogFiles = objWMIService.ExecQuery ("SELECT * FROM > Win32_NTEventLogFile WHERE LogFileName='" & logType & "'") > > > For Each objLogfile in colLogFiles > errBackupLog = objLogFile.BackupEventLog(fullPathName) > > If errBackupLog = 0 Then > Wscript.Echo "The Security event log was backed up." > objLogFile.ClearEventLog() > End If > If errBackupLog = 8 Then > Wscript.Echo "Privilege missing!" > End If > If errBackupLog = 21 Then > Wscript.Echo "Invalid Parameter in call" > End If > > If errBackupLog = 183 Then > Wscript.Echo "The archive file already exists." > End If > Next > ===================END -- Gerry Hickman (London UK) |
| Logon Script Causing Laptops To Hang - Problems in script? | VB Script | |||
| problem passing args to script 'There is no script engine for file extenstion' | VB Script | |||
| Is there any compatibility issue between 2005 R2 and 2005 R2 SP1 f | Virtual Server | |||
| Difference between VS 2005 and VS 2005 Express | .NET General | |||
| Installing Visual Studio 2005 Std Ed, SQL Server 2005 Expr./Compac | Vista installation & setup | |||
