| | EnablePrivileges = True not working in wmi connection I'm trying to (programatically) backup and clear the security event log on the local machine. I can do this manually through the event viewer and I am logged on as an administrator. I can successfully connect to the local wmi service. I can step through and list all the log files on the local computer in a text box so I know I can get an System.Management.ManagementObject that is the security log. However when I try to execute the "BackupEventLog" method I get access denied. Here is my code for trying to execute the method: logfileSearcher = New System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, "Select * from win32_NTEventLogFile WHERE LogFileName='security'") '* execute query '* Get Event Log Files logfiles = logfileSearcher.Get() For Each logfile In logfiles Dim inParams As Management.ManagementBaseObject = logfile.GetMethodParameters("BackupEventLog") inParams("ArchiveFileName") = "c:\testing.evt" Dim outParams As Management.ManagementBaseObject = logfile.InvokeMethod("BackupEventLog", inParams, Nothing) Next Here is the error detail: Error Encountered: System.Management.ManagementException: Access denied at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode) at System.Management.ManagementObject.InvokeMethod(String methodName, ManagementBaseObject inParameters, InvokeMethodOptions options) at wmitest.Form1.Button3_Click(Object sender, EventArgs e) in C:\Documents and Settings\1069317\Desktop\Desktop Stuff\JTSecuAudit\wmitest\Form1.vb:line 75 I have checked around on google and found that several people have had similar issues and it has to do with the privileges of the wmi connection. I am logged onto the machine as an administrator, I have also set the ConnectionOptions.EnablePrivileges = True But it does not work...I have found threads online indicating that setting EnablePrivileges to True worked on .NET framework 1.0 but it "stopped" working on 1.1 and I assume doesn't work on 2.0 as I am having this issue. (I am using .NET Framework 2.0 SP1). please help! |
| | RE: EnablePrivileges = True not working in wmi connection "JohnBates" wrote: Quote: > I'm trying to (programatically) backup and clear the security event log on > the local machine. I can do this manually through the event viewer and I am > logged on as an administrator. I can successfully connect to the local wmi > service. I can step through and list all the log files on the local computer > in a text box so I know I can get an System.Management.ManagementObject that > is the security log. > > However when I try to execute the "BackupEventLog" method I get access > denied. > > Here is my code for trying to execute the method: > > logfileSearcher = New > System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, > "Select * from win32_NTEventLogFile WHERE LogFileName='security'") > '* execute query > '* Get Event Log Files > logfiles = logfileSearcher.Get() > > For Each logfile In logfiles > Dim inParams As Management.ManagementBaseObject = > logfile.GetMethodParameters("BackupEventLog") > inParams("ArchiveFileName") = "c:\testing.evt" > Dim outParams As Management.ManagementBaseObject = > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > Next > > Here is the error detail: > > Error Encountered: System.Management.ManagementException: Access denied > at > System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus > errorCode) > at System.Management.ManagementObject.InvokeMethod(String methodName, > ManagementBaseObject inParameters, InvokeMethodOptions options) > at wmitest.Form1.Button3_Click(Object sender, EventArgs e) in > C:\Documents and Settings\1069317\Desktop\Desktop > Stuff\JTSecuAudit\wmitest\Form1.vb:line 75 > > > I have checked around on google and found that several people have had > similar issues and it has to do with the privileges of the wmi connection. I > am logged onto the machine as an administrator, I have also set the > ConnectionOptions.EnablePrivileges = True > > But it does not work...I have found threads online indicating that setting > EnablePrivileges to True worked on .NET framework 1.0 but it "stopped" > working on 1.1 and I assume doesn't work on 2.0 as I am having this issue. > (I am using .NET Framework 2.0 SP1). > > please help! This worked for me on .NET Framework 2.0: Dim scope As New ManagementScope scope.Options.EnablePrivileges = True logfileSearcher = New System.Management.ManagementObjectSearcher(scope, New Management.ObjectQuery("Select * from win32_NTEventLogFile WHERE LogFileName='security'")) logfiles = logfileSearcher.Get() For Each logfile In logfiles Dim inParams As Management.ManagementBaseObject = logfile.GetMethodParameters("BackupEventLog") inParams("ArchiveFileName") = "c:\testing.evt" Dim outParams As Management.ManagementBaseObject = logfile.InvokeMethod("BackupEventLog", inParams, Nothing) Console.WriteLine(outParams.Item("returnValue")) Next -- urkec |
| | RE: EnablePrivileges = True not working in wmi connection urkec - first off thank you so much for your help your code does work...let me post my original connection code (which doesn't seem to work) I think the difference was that I was attempting to create a connection using impersonate and authentication...without those it works. based on the working wmi vbsscript I had I thought I had to use impersonate and authentication. My Connection Code: ===================BEGIN With myConnectionOptions .Impersonation = Management.ImpersonationLevel.Impersonate .Authentication = System.Management.AuthenticationLevel.Packet End With If Not Me.txtUsername.Text = "" Then myConnectionOptions.Username = Me.txtUsername.Text Else myConnectionOptions.Username = Nothing End If If Not Me.txtPassword.Text = "" Then myConnectionOptions.Password = Me.txtPassword.Text Else myConnectionOptions.Password = Nothing End If If Me.CheckBox1.Checked = True Then myConnectionOptions.EnablePrivileges = True End If '* Replace the "." with an actual servername for remote connection 'Dim myServerName As String = "." Dim myServerName As String = Me.txtServer.Text myManagementScope = New System.Management.ManagementScope("\\" & myServerName & "\root\cimv2", myConnectionOptions) '* connect to WMI namespace myManagementScope.Connect() If myManagementScope.IsConnected = False Then rtbStatus.AppendText("Could not connect to WMI namespace on " & myServerName & ControlChars.Cr) Else rtbStatus.AppendText("Connected to WMI namespace on " & myServerName & ControlChars.Cr) End If ===================END I'm getting a little closer to my final end product - now I just can't seem to get the ClearLogFile method to work. I tried using the Nothing keyword in place of the options object but it choked on that. Any other ideas? Here is what I am doing now: ===================BEGIN Dim scope As New ManagementScope("\\" & Me.txtServer.Text & "\root\cimv2") Dim logfileSearcher As System.Management.ManagementObjectSearcher Dim logfiles As System.Management.ManagementObjectCollection Dim logfile As System.Management.ManagementObject Dim logQuery As New Management.ObjectQuery("Select * from win32_NTEventLogFile WHERE LogFileName='security'") Me.rtbStatus.Clear() Try If Me.txtUsername.Text = "" Then scope.Options.Username = Nothing Else scope.Options.Username = Me.txtUsername.Text End If If Me.txtPassword.Text = "" Then scope.Options.Password = Nothing Else scope.Options.Password = Me.txtPassword.Text End If If Me.CheckBox1.Checked = True Then scope.Options.EnablePrivileges = True End If scope.Connect() If scope.IsConnected = False Then rtbStatus.AppendText("Could not connect to WMI namespace on " & Me.txtServer.Text & ControlChars.Cr) Else rtbStatus.AppendText("Connected to WMI namespace on " & Me.txtServer.Text & ControlChars.Cr) End If logfileSearcher = New System.Management.ManagementObjectSearcher(scope, logQuery) logfiles = logfileSearcher.Get() For Each logfile In logfiles 'Backup Log File Dim inParams As Management.ManagementBaseObject = logfile.GetMethodParameters("BackupEventLog") inParams("ArchiveFileName") = "c:\testing.evt" Dim outParams As Management.ManagementBaseObject = logfile.InvokeMethod("BackupEventLog", inParams, Nothing) 'Backup Result rtbStatus.AppendText("Backup Method Returned : " & outParams.Item("returnValue").ToString & " ") If outParams.Item("returnValue").ToString = 0 Then rtbStatus.AppendText("The Security event log was backed up." & ControlChars.Cr) 'Only execute ClearEventLog method upon successful Backup outParams = logfile.InvokeMethod("ClearEventLog", inParams, Nothing) 'Diplay Clear Result rtbStatus.AppendText("Clear Method Returned : " & outParams.Item("returnValue").ToString & ControlChars.Cr) End If If outParams.Item("returnValue").ToString = 8 Then rtbStatus.AppendText("Privilege missing!" & ControlChars.Cr) End If If outParams.Item("returnValue").ToString = 21 Then rtbStatus.AppendText("Invalid Parameter in call" & ControlChars.Cr) End If If outParams.Item("returnValue").ToString = 183 Then rtbStatus.AppendText("The archive file already exists." & ControlChars.Cr) End If Next Catch ex As Exception rtbStatus.AppendText("Error Encountered: " & ex.ToString & ControlChars.Cr) End Try ===================END "urkec" wrote: Quote: > "JohnBates" wrote: > Quote: > > I'm trying to (programatically) backup and clear the security event log on > > the local machine. I can do this manually through the event viewer and I am > > logged on as an administrator. I can successfully connect to the local wmi > > service. I can step through and list all the log files on the local computer > > in a text box so I know I can get an System.Management.ManagementObject that > > is the security log. > > > > However when I try to execute the "BackupEventLog" method I get access > > denied. > > > > Here is my code for trying to execute the method: > > > > logfileSearcher = New > > System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, > > "Select * from win32_NTEventLogFile WHERE LogFileName='security'") > > '* execute query > > '* Get Event Log Files > > logfiles = logfileSearcher.Get() > > > > For Each logfile In logfiles > > Dim inParams As Management.ManagementBaseObject = > > logfile.GetMethodParameters("BackupEventLog") > > inParams("ArchiveFileName") = "c:\testing.evt" > > Dim outParams As Management.ManagementBaseObject = > > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > > Next > > > > Here is the error detail: > > > > Error Encountered: System.Management.ManagementException: Access denied > > at > > System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus > > errorCode) > > at System.Management.ManagementObject.InvokeMethod(String methodName, > > ManagementBaseObject inParameters, InvokeMethodOptions options) > > at wmitest.Form1.Button3_Click(Object sender, EventArgs e) in > > C:\Documents and Settings\1069317\Desktop\Desktop > > Stuff\JTSecuAudit\wmitest\Form1.vb:line 75 > > > > > > I have checked around on google and found that several people have had > > similar issues and it has to do with the privileges of the wmi connection. I > > am logged onto the machine as an administrator, I have also set the > > ConnectionOptions.EnablePrivileges = True > > > > But it does not work...I have found threads online indicating that setting > > EnablePrivileges to True worked on .NET framework 1.0 but it "stopped" > > working on 1.1 and I assume doesn't work on 2.0 as I am having this issue. > > (I am using .NET Framework 2.0 SP1). > > > > please help! > > This worked for me on .NET Framework 2.0: > > Dim scope As New ManagementScope > scope.Options.EnablePrivileges = True > > logfileSearcher = New > System.Management.ManagementObjectSearcher(scope, New > Management.ObjectQuery("Select * from win32_NTEventLogFile WHERE > LogFileName='security'")) > logfiles = logfileSearcher.Get() > > For Each logfile In logfiles > > Dim inParams As Management.ManagementBaseObject = > logfile.GetMethodParameters("BackupEventLog") > inParams("ArchiveFileName") = "c:\testing.evt" > Dim outParams As Management.ManagementBaseObject = > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > Console.WriteLine(outParams.Item("returnValue")) > > Next > > > -- > urkec |
| | RE: EnablePrivileges = True not working in wmi connection Actually I got it to work...I have to reset the inParams object to the parameters for the ClearLogFile method with: inParams = logfile.GetMethodParameters("ClearEventLog") before the line: outParams = logfile.InvokeMethod("ClearEventLog", inParams, Nothing) It just would not accept Nothing in place of the base object. Again thank you so much for your help. "JohnBates" wrote: Quote: > urkec - first off thank you so much for your help your code does work...let > me post my original connection code (which doesn't seem to work) I think the > difference was that I was attempting to create a connection using impersonate > and authentication...without those it works. based on the working wmi > vbsscript I had I thought I had to use impersonate and authentication. > > My Connection Code: > ===================BEGIN > With myConnectionOptions > .Impersonation = Management.ImpersonationLevel.Impersonate > .Authentication = System.Management.AuthenticationLevel.Packet > End With > > If Not Me.txtUsername.Text = "" Then > myConnectionOptions.Username = Me.txtUsername.Text > Else > myConnectionOptions.Username = Nothing > End If > If Not Me.txtPassword.Text = "" Then > myConnectionOptions.Password = Me.txtPassword.Text > Else > myConnectionOptions.Password = Nothing > End If > If Me.CheckBox1.Checked = True Then > myConnectionOptions.EnablePrivileges = True > End If > > > '* Replace the "." with an actual servername for remote connection > 'Dim myServerName As String = "." > Dim myServerName As String = Me.txtServer.Text > myManagementScope = New System.Management.ManagementScope("\\" & > myServerName & "\root\cimv2", myConnectionOptions) > > '* connect to WMI namespace > myManagementScope.Connect() > If myManagementScope.IsConnected = False Then > rtbStatus.AppendText("Could not connect to WMI namespace on " & > myServerName & ControlChars.Cr) > Else > rtbStatus.AppendText("Connected to WMI namespace on " & > myServerName & ControlChars.Cr) > End If > > ===================END > > > I'm getting a little closer to my final end product - now I just can't seem > to get the ClearLogFile method to work. I tried using the Nothing keyword in > place of the options object but it choked on that. Any other ideas? > > Here is what I am doing now: > > ===================BEGIN > Dim scope As New ManagementScope("\\" & Me.txtServer.Text & > "\root\cimv2") > Dim logfileSearcher As System.Management.ManagementObjectSearcher > Dim logfiles As System.Management.ManagementObjectCollection > Dim logfile As System.Management.ManagementObject > Dim logQuery As New Management.ObjectQuery("Select * from > win32_NTEventLogFile WHERE LogFileName='security'") > > Me.rtbStatus.Clear() > > Try > > If Me.txtUsername.Text = "" Then > scope.Options.Username = Nothing > Else > scope.Options.Username = Me.txtUsername.Text > End If > If Me.txtPassword.Text = "" Then > scope.Options.Password = Nothing > Else > scope.Options.Password = Me.txtPassword.Text > End If > If Me.CheckBox1.Checked = True Then > scope.Options.EnablePrivileges = True > End If > > scope.Connect() > > If scope.IsConnected = False Then > rtbStatus.AppendText("Could not connect to WMI namespace on > " & Me.txtServer.Text & ControlChars.Cr) > Else > rtbStatus.AppendText("Connected to WMI namespace on " & > Me.txtServer.Text & ControlChars.Cr) > End If > > logfileSearcher = New > System.Management.ManagementObjectSearcher(scope, logQuery) > logfiles = logfileSearcher.Get() > > For Each logfile In logfiles > 'Backup Log File > Dim inParams As Management.ManagementBaseObject = > logfile.GetMethodParameters("BackupEventLog") > inParams("ArchiveFileName") = "c:\testing.evt" > Dim outParams As Management.ManagementBaseObject = > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > > 'Backup Result > rtbStatus.AppendText("Backup Method Returned : " & > outParams.Item("returnValue").ToString & " ") > If outParams.Item("returnValue").ToString = 0 Then > rtbStatus.AppendText("The Security event log was backed > up." & ControlChars.Cr) > 'Only execute ClearEventLog method upon successful Backup > outParams = logfile.InvokeMethod("ClearEventLog", > inParams, Nothing) > 'Diplay Clear Result > rtbStatus.AppendText("Clear Method Returned : " & > outParams.Item("returnValue").ToString & ControlChars.Cr) > End If > If outParams.Item("returnValue").ToString = 8 Then > rtbStatus.AppendText("Privilege missing!" & > ControlChars.Cr) > End If > If outParams.Item("returnValue").ToString = 21 Then > rtbStatus.AppendText("Invalid Parameter in call" & > ControlChars.Cr) > End If > > If outParams.Item("returnValue").ToString = 183 Then > rtbStatus.AppendText("The archive file already exists." > & ControlChars.Cr) > End If > > Next > Catch ex As Exception > rtbStatus.AppendText("Error Encountered: " & ex.ToString & > ControlChars.Cr) > End Try > ===================END > > > "urkec" wrote: > Quote: > > "JohnBates" wrote: > > Quote: > > > I'm trying to (programatically) backup and clear the security event log on > > > the local machine. I can do this manually through the event viewer and I am > > > logged on as an administrator. I can successfully connect to the local wmi > > > service. I can step through and list all the log files on the local computer > > > in a text box so I know I can get an System.Management.ManagementObject that > > > is the security log. > > > > > > However when I try to execute the "BackupEventLog" method I get access > > > denied. > > > > > > Here is my code for trying to execute the method: > > > > > > logfileSearcher = New > > > System.Management.ManagementObjectSearcher(myManagementScope.Path.ToString, > > > "Select * from win32_NTEventLogFile WHERE LogFileName='security'") > > > '* execute query > > > '* Get Event Log Files > > > logfiles = logfileSearcher.Get() > > > > > > For Each logfile In logfiles > > > Dim inParams As Management.ManagementBaseObject = > > > logfile.GetMethodParameters("BackupEventLog") > > > inParams("ArchiveFileName") = "c:\testing.evt" > > > Dim outParams As Management.ManagementBaseObject = > > > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > > > Next > > > > > > Here is the error detail: > > > > > > Error Encountered: System.Management.ManagementException: Access denied > > > at > > > System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus > > > errorCode) > > > at System.Management.ManagementObject.InvokeMethod(String methodName, > > > ManagementBaseObject inParameters, InvokeMethodOptions options) > > > at wmitest.Form1.Button3_Click(Object sender, EventArgs e) in > > > C:\Documents and Settings\1069317\Desktop\Desktop > > > Stuff\JTSecuAudit\wmitest\Form1.vb:line 75 > > > > > > > > > I have checked around on google and found that several people have had > > > similar issues and it has to do with the privileges of the wmi connection. I > > > am logged onto the machine as an administrator, I have also set the > > > ConnectionOptions.EnablePrivileges = True > > > > > > But it does not work...I have found threads online indicating that setting > > > EnablePrivileges to True worked on .NET framework 1.0 but it "stopped" > > > working on 1.1 and I assume doesn't work on 2.0 as I am having this issue. > > > (I am using .NET Framework 2.0 SP1). > > > > > > please help! > > > > This worked for me on .NET Framework 2.0: > > > > Dim scope As New ManagementScope > > scope.Options.EnablePrivileges = True > > > > logfileSearcher = New > > System.Management.ManagementObjectSearcher(scope, New > > Management.ObjectQuery("Select * from win32_NTEventLogFile WHERE > > LogFileName='security'")) > > logfiles = logfileSearcher.Get() > > > > For Each logfile In logfiles > > > > Dim inParams As Management.ManagementBaseObject = > > logfile.GetMethodParameters("BackupEventLog") > > inParams("ArchiveFileName") = "c:\testing.evt" > > Dim outParams As Management.ManagementBaseObject = > > logfile.InvokeMethod("BackupEventLog", inParams, Nothing) > > Console.WriteLine(outParams.Item("returnValue")) > > > > Next > > > > > > -- > > urkec |
| Operator -not should get True for whatever -eq 0 gets True (and morefun) | PowerShell | |||
| Acroness true image not working, Vista crash dumps | Software | |||
| True number of true Vista users | Vista General | |||
| How do I set up a working VPN connection in Vista? | Vista networking & sharing | |||
| How do I set up a working VPN connection in Vista? | Vista General | |||
