| | Null Reference error when clicking on NumericUpDown control Hi, I have used NumericUpDown Control in my application. Clicking continuously on it would result Null reference error. System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.UpDownButtons.TimerHandler(Object source, EventArgs args) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime) I am not understanding why.. Could anyone give me suggestions as how to avoid this exception. Thank you, Regards, Bharathi |
| Re: "Error: 'null' is null or not an object" when trying to view video | Vista performance & maintenance | |||
| Gotcha: $null to [string] IS NOT $null | PowerShell | |||
| Error message for 1/$null | PowerShell | |||
