| | How to generate the reference number Hi, I want to generate a series of number in a Form as reference number automatically. It likes 0804-0001, 0804-0002,........................ in each record. Besides, I also face the problem in printing by using reportview class. a) sorting by SalesID? b) I just need to print 1 record information only if sorting by SalesID. however, it generated all round SalesID started from initially. (such as record 1,2,3,4,5,.............) c) How do I make to print 2 copys in 1 record ? (one for customer another for us) Anyone help? Thanks |
| Line number reference, runtime | VB Script | |||
| Generate script | VB Script | |||
| Re: performance rating; any reference number? | Vista performance & maintenance | |||
