Vista - Active X replacement in VS2003
Old 04-23-2008   #1 (permalink)
Christian Schönig
Hi there,
pretty stupid and general question of a newbe, but thats wat I want:
I want to make some kind of plug-in which can be used by all kinds of
windows applications like Word and so on. In former years we were using
active X. Now I am sitting at VS2003 under C# and try to do something
similar. I know there must be a way! Can somebody point me out where the
handbook for that is located in the internet or give me the right technology
word so I can search on?
Old 04-23-2008   #2 (permalink)
Marc Gravell
Re: Active X replacement in VS2003
Well, if you want to use .NET, then you can use "tlbexp" to expose an
assembly as an ActiveX library, having marked which types and members
you want to be visible via [ComVisible(true/false)] etc.
You can control a lot more, but it is a big area; but if you look for
"tlbexp" there will be *lots* of material explaining how to do it...
Note that you can't create an ActiveX server in this way...
Marc
RE: VB Express 2008 Vs VS2003 Professional .NET General
Parallel installation of VC6, VS2003 and VS2008 .NET General
How to debug component written in VS2003 in a VS2005 application .NET General
VS2003 - File.Delete does not work in Vista? Vista performance & maintenance
