| | Help: System.Threading.Timer doesn't work! Hi, In my code, I observe an event. In the event handler, I have: if (mIsMarketOpen == false) { // Execute "CheckHistoricalData" every 15 seconds System.Threading.Timer timer = new Timer(CheckHistoricalData, null, 1000, 15000); mIsMarketOpen = true; } But "CheckHistoricalData" method is never executed! Anyone can tell me anything I did wrong? Thanks! |
| | Re: Help: System.Threading.Timer doesn't work! Curious wrote: Quote: > In my code, I observe an event. In the event handler, I have: > > if (mIsMarketOpen == false) > { > // Execute "CheckHistoricalData" every 15 > seconds > System.Threading.Timer timer = new > Timer(CheckHistoricalData, null, 1000, 15000); > mIsMarketOpen = true; > } > > But "CheckHistoricalData" method is never executed! Anyone can tell me > anything I did wrong? Thanks! for garbage collection. You'll want to move the timer reference and creation to outside the event handler, for example: private readonly Timer historicalDataTimer = new Timer(CheckHistoricalData); Then in the event handler you can do: historicalDataTimer.Change(1000, 15000); -- J. http://symbolsprose.blogspot.com |
| System.OutOfMemoryException thrown by System.Threading.Thread.Slee | .NET General | |||
| System restore and other system apps do not work | Vista General | |||
| E-mail: threading | Live Mail | |||
| start System.Threading.Thread | PowerShell | |||
| Info: Can You Create Threads using System.Threading | PowerShell | |||
