| | Build Events question on project name and path I have a solution under VS2005 were there are two projects. One project is physically located under the Solution folder. One project is physically not located under the Solution folder. In the BuildEvents.OnBuildProjConfigBegin event in EnvironmentEvents file the first parameter is Project which is a string with the realative path and project file name. I am in search of how to get the absolute path and project file name. So I get this from the project param .../../Jenkins/PDF_Extraction/bin/Debug/PDF_Extraction.exe I want .../../Jenkins/PDF_Extraction/PDF_Extraction.vbproj or the absolute path as shown below C:/DotNetLand/Jenkins/PDF_Extraction/PDF_Extraction.vbproj Any help would be great, thanks in advance Kevin kevin.s.gallagher@xxxxxx |
| [Project] My HAF 932 Water-Cooling Build *56K Warning* | Overclocking & Cooling | |||
| Stationery path question | Vista performance & maintenance | |||
| Microsoft Project 2007 Uninstallation Question | Microsoft Office | |||
| Project build and publish error | .NET General | |||
