Vista - Create ActiveX control using Visual Net 2005
Old 04-23-2008   #1 (permalink)
estufa
Hi
I see some questions about creating ActiveX controls using .NET.
I found the answer in this page and it works really good for me.
http://www.codeproject.com/KB/miscct...00&msg=1336367
Good luck.
Old 04-24-2008   #2 (permalink)
Scott M.
Re: Create ActiveX control using Visual Net 2005
Just to be clear, you cannot create an ActiveX control using .NET. What
that article describes is how to expose a .NET Windows Form to a COM
application via InterOp so that the COM application believes it is accessing
an ActiveX control. But, in actuality, you have not created an ActiveX
control.
-Scott
"estufa" <estufa8@xxxxxx> wrote in message
news:5f1fa67f-422f-4ebd-8d34-7266ad89cb08@xxxxxx
Quote:
> Hi
> Good luck.
Old 05-07-2008   #3 (permalink)
estufa
Ok, thanks.
Anyhow, it works fine. 8-)
I'm using them with CobolWOW (IDE for Cobol) and they do work.
Regards.
Error=429: ActiveX component can't create object Vista General
Error=429 : ActiveX component can't create object Vista General
Installing Visual Studio 2005 Std Ed, SQL Server 2005 Expr./Compac Vista installation & setup
Error 429 : ActiveX component can't create object Vista General
ActiveX Control prompt "An ActiveX control on this page might be u Vista General
