| | Using a C# Class Library with VB6 I hope I'm posting this in the right place.... I have a new C# class library written in Visual Studio 2008. I also have an existing VB6 application that I have been maintaining for some time. In the configuration of the class library I have enabled "Make assemble COM-Visible" and "Register for COM interop" When I build the class library on my development machine I am able to see and reference it from my VB6 application as I do many other dlls. However, I am having a real headache when it comes to deploying my application. I usualy build my MSI using InstallShield and have added the dll and it's associated tlb to the package. However when I attempt to run the released application on a test machine it fails with an error 429. If I run the application in debug mode, if breaks the first time it attempts to reference anything to do with my new class library. Can anyone give me some pointers as to what I should be doing in order to run my application on anything other than my development machine? |
| | RE: Using a C# Class Library with VB6 Have you registered the VB6 runtime and used regasm on the C# class library? -- Browse http://connect.microsoft.com/VisualStudio/feedback/ and vote. http://www.peterRitchie.com/blog/ Microsoft MVP, Visual Developer - Visual C# "lord.torall@xxxxxx" wrote: Quote: > I hope I'm posting this in the right place.... > > I have a new C# class library written in Visual Studio 2008. I also > have an existing VB6 application that I have been maintaining for some > time. > > In the configuration of the class library I have enabled "Make > assemble COM-Visible" and "Register for COM interop" > > When I build the class library on my development machine I am able to > see and reference it from my VB6 application as I do many other dlls. > However, I am having a real headache when it comes to deploying my > application. I usualy build my MSI using InstallShield and have added > the dll and it's associated tlb to the package. However when I attempt > to run the released application on a test machine it fails with an > error 429. If I run the application in debug mode, if breaks the first > time it attempts to reference anything to do with my new class > library. > > Can anyone give me some pointers as to what I should be doing in order > to run my application on anything other than my development machine? > |
| | Re: Using a C# Class Library with VB6 On Fri, 25 Apr 2008 07:18:47 -0700 (PDT), lord.torall@xxxxxx wrote: Quote: >I hope I'm posting this in the right place.... > >I have a new C# class library written in Visual Studio 2008. I also >have an existing VB6 application that I have been maintaining for some >time. > >In the configuration of the class library I have enabled "Make >assemble COM-Visible" and "Register for COM interop" > >When I build the class library on my development machine I am able to >see and reference it from my VB6 application as I do many other dlls. >However, I am having a real headache when it comes to deploying my >application. I usualy build my MSI using InstallShield and have added >the dll and it's associated tlb to the package. However when I attempt >to run the released application on a test machine it fails with an >error 429. If I run the application in debug mode, if breaks the first >time it attempts to reference anything to do with my new class >library. > >Can anyone give me some pointers as to what I should be doing in order >to run my application on anything other than my development machine? class and on your interfaces. Then, you need to make sure to register your assembly after you've deployed using regasm.exe. This article should help http://msdn2.microsoft.com/en-us/library/c3fd4a20.aspx |
| Icons in dll / assembly / class library | .NET General | |||
| Adding class library to website | .NET General | |||
| Re: invisible classes outside the Class Library | .NET General | |||
| RE: invisible classes outside the Class Library | .NET General | |||
| Summary comments in Class Library | .NET General | |||
